1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    Recently put 3K miles on my prius from 5/18 till today 6/15. Message came up for oil maintenance but I checked the oil and it still looks new, what should I do? How often should I change oil?
    51,841
    every 10,000 miles. the message comes up every 5,000 so you will remember to do the odd things like tyre rotation, cabin filter, and etc., check your o/m maint. guide. did it really say 'oil'?
  3. Dan05979
    Dan05979 Member
    181
    101
  4. bisco
    51,841
    thanks, it was 5,000 on the gen II, but they changed it to 10,000 on the gen III with synthetic oil and left the reminder at 5,000 for the other things. apparently, they were too lazy to reprogram the message.the method is in the o/m. it's fairly complicated, so i can't remember. it's like 'put on your seat belt, open the drivers door, turn the headlights on and off three times, hold the odometer button, turn your head and cough.
  5. Dan05979
    Dan05979 Member
    181
    101
    So 10K for an oil change..I guess that's the normal now because My 2011 5 series is every 15K which I find bizarre but ok. So how do i get rid of this message?
  6. lester williams
    227
    68
    mississippi
    Saying this off memory,,,,,, get in car and hold down little button on dash on right side of steering wheel marked kph/mph at the same time as pushing and holding in ''start'' button. I think this works the same with either foot on brake or not and you will see a little line starting across from left to right as it resets. It does not take but a few seconds to reset. If I left something out--- someone will be along with proper instructions.
    Dan05979 likes this.
  7. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    Proper instructions are in your owner's manual.
  8. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    The display needs to be on "Trip A" before doing the KPH/MPH and Start button push. Again, it's in the owner's manual.
  9. lester williams
    227
    68
    mississippi
    Yeah,, I forgot about ''trip A'', then proceed as I said. Hold in the kph/mph button and push and hold ''start'' until reset
  10. Dan05979
    Dan05979 Member
    181
    101
    Thanks guy's I'll try it tonight when i head for work
  11. lester williams
    227
    68
    mississippi
    Duh,,, there is a sticky at the top of this thread on procedure---- where I got my original info.....
  12. Dan05979
    Dan05979 Member
    181
    101
    Holy shirt, I totally didn't see that lol
  13. lester williams
    227
    68
    mississippi
    I knew it was SOMEWHERE,, old and basically computer illiterate and I never had much success at ''searching''--- I jus aggravate people and ask in a thread........
  14. Dan05979
    Dan05979 Member
    181
    101
    well, it's not the end of the world.
  15. CR94
    CR94 Senior Member
    2,687
    1,166
    Northwestern S.C.
    The instructions in the manual a bit ambiguous, but I interpret them to mean it's the "MPH or km/h button" you're supposed to continue holding down until reset is complete, not the "POWER" button.
  16. RRxing
    2,545
    1,821
    NEPA
    You hold BOTH down...
  17. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Here's what the manual says in Chapter 4:
    After the required maintenance is performed according to the maintenance schedule, please reset the maintenance data.
    To reset the data, follow the procedures described below:
    1. Turn the “POWER” switch off with the trip meter A shown.
    2. Turn the “POWER” switch to ON mode with the MPH or km/h button held down.
    3. Keep pressing the button until the trip meter indicates “000000” and the multi-information display indicates that the reset is complete.
    IIRC, the last time I did this, I only pressed the Power button long enough for the display to turn on. I pressed the MPH button until it said the reset was complete. Note that it differentiates between the Power switch and the MPH button. Note that it also states "the MPH or km/h button".
