Please post your UOA here to compare.
Discussion in 'Gen 3 Prius Technical Discussion' started by szgabor, Dec 12, 2009.
  1. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    Throwing around non-standard home-made and insider acronyms instead of plain-English equivalents somehow makes some people feel superior. That habit is caused by a combination of laziness and elitism.
  2. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    sorry I made you feel inferior :) (actually you did it to yourself )
    But the fact is that this (UOA) IS a common acronym on blogs where car maintenance are discussed. And this is a technical thread of a CAR more specifically Gen 3 prius ... where among other things common maintenance like oil change and other stuff like, you know, MPG, ATF-WS, OCI , CVT etc comes up time to time ....
  3. lester williams
    227
    68
    mississippi
    After reading these threads, I had the dealer change my ATF at 15K miles, [ after tearing and surgery for meniscus tendon ]. I changed the wife's fluid myself at 55K in her 2012 ''v'' a few months before this, and it was BLACK. I goofed around and forgot my sample bottle when going to the dealer, and have kicked myself for being so negligent. My next oil change, I will get a UOA and my ATF also around 55--60K.
    bwilson4web likes this.
  4. Former Member 68813
    3,524
    983
    US
    i consider comments like that a gross exaggeration. now if you had a picture of oil blotted on paper towel, we could discuss it.
  5. lester williams
    227
    68
    mississippi
    All righty then--- it was a very, very dark brownish black without any hint of factory red/cherry. Better, Thomas??
    CR94 likes this.
  6. szgabor
    994
    175
    Oceanside NY
    Here is the 40k UOA
  7. szgabor
    994
    175
    Oceanside NY
    Latest Used Oil Analysis (UOA) at 50K
  8. szgabor
    994
    175
    Oceanside NY
  9. szgabor
    994
    175
    Oceanside NY
    Since the original post CANNOT be edited anymore (not sure why it was pretty convenient updating the original post)
    I am putting a table here with all the data as it comes in time..... hope this is useful...
    The newest change was done a little early, only because I needed a state inspection and did not want to go twice in two weeks ... and this way actually the inspection was "free"
    Mile on car 58994 50000 40885 30128 20000 10051 5400
    1 Mile on Oil 8845 10000 10756 10k 10k 5k 5.4k
    2 Date 2/2/17 06/04/16 09/17/15 05/09/15 08/30/14 10/07/13 05/10/13
    3 Oil type Syn 0W20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20
    4 Oil brand Toyota Toyota Toyota (Toyota) (Toyota) (Mobil 1) (Factory OEM)
    5 Make Up Oil qrt 0 0 0 0 0 0 0
    6 ALUMINUM 4 5 3 4 7 6 8
    7 CHROMIUM 0 0 0 0 0 0 0
    8 IRON 9 7 5 5 9 7 17
    9 COPPER 1 1 1 1 3 12 62
    10 LEAD 0 0 0 0 0 0 0
    11 TIN 0 3 0 0 0 0 0
    12 MOLYBDENUM 37 36 40 46 44 71 100
    13 NICKEL 0 0 0 0 0 0 0
    14 MANGANESE 0 0 0 0 0 0 2
    15 SILVER 0 0 0 0 0 0 0
    16 TITANIUM 0 0 0 0 0 0 0
    17 POTASSIUM 2 2 0 6 0 1 0
    18 BORON 8 2 7 14 20 91 2
    19 SILICON 8 9 8 6 17 47 206
    20 SODIUM 6 6 9 5 5 4 5
    21 CALCIUM 2012 2103 2301 2712 1974 2315 1981
    22 MAGNESIUM 13 9 11 15 14 38 13
    23 PHOSPHORUS 560 513 564 762 487 823 687
    24 ZINC 631 616 683 876 596 916 769
    25 BARIUM 0 0 0 0 0 0 2
    26
    27 SUS Vis @ 210°F 49.6 48.6 53 49.0 48.3 49.3 48.1
    28 cSt Vis @ 100°C 7.15 6.85 8.19 6.97 6.76 7.07 6.69
    29 Flashpoint °F 330 365 400 375 390 385 395
    30 Fuel % 2.8 1 <0.5 <0.5 <0.5 TR <0.5
    31 Antifreeze % 0 0.0 0.0 0.0 0.0 0.0 0.0
    32 Water % 0 0.0 0.0 0.0 0.0 0.0 0.0
    33 Insolubles % 0.3 TR 0.3 0.1 0.3 0.4 0.4
    Updated 3/8/2017
  10. bisco
    52,286
    thanks! will you be able to update the table?
  11. szgabor
    994
    175
    Oceanside NY
    the above (your post IS the updated one) unfortunately the original post is no longer editable I thought it was neat that I was able to add almost 4 year of data .....
    so yes my last post is the updated table (you can see from the dates)
  12. bisco
    52,286
    agreed. this new edit rule seems ridiculous.
    m.wynn likes this.
  13. szgabor
    994
    175
    Oceanside NY
    I thought maybe a thread to collect this information is useful for all. (moderator please feel free to correct me)
    Since the older posts are non-editable. I am quoting the last table and adding to it as it goes
    See bellow the updated report including the most recent data.
    Here it is.
    Mile on car 65824 58994 50000 40885 30128 20000 10051 5400
    1 Mile on Oil 6830 8845 10000 10756 10k 10k 5k 5.4k
    2 Date 09/07/17 02/02/17 06/04/16 09/17/15 05/09/15 08/30/14 10/07/13 05/10/13
    3 Oil type Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20
    4 Oil brand Toyota Toyota Toyota Toyota (Toyota) (Toyota) (Mobil 1) (Factory OEM)
    5 Make Up Oil qrt 0 0 0 0 0 0 0 0
    6 ALUMINUM 4 4 5 3 4 7 6 8
    7 CHROMIUM 0 0 0 0 0 0 0 0
    8 IRON 5 9 7 5 5 9 7 17
    9 COPPER 1 1 1 1 1 3 12 62
    10 LEAD 0 0 0 0 0 0 0 0
    11 TIN 0 0 3 0 0 0 0 0
    12 MOLYBDENUM 41 37 36 40 46 44 71 100
    13 NICKEL 0 0 0 0 0 0 0 0
    14 MANGANESE 0 0 0 0 0 0 0 2
    15 SILVER 0 0 0 0 0 0 0 0
    16 TITANIUM 0 0 0 0 0 0 0 0
    17 POTASSIUM 0 2 2 0 6 0 1 0
    18 BORON 5 8 2 7 14 20 91 2
    19 SILICON 8 8 9 8 6 17 47 206
    20 SODIUM 5 6 6 9 5 5 4 5
    21 CALCIUM 2097 2021 2103 2301 2712 1974 2315 1981
    22 MAGNESIUM 18 13 9 11 15 14 38 13
    23 PHOSPHORUS 598 560 513 564 762 487 823 687
    24 ZINC 665 631 616 683 876 596 916 769
    25 BARIUM 0 0 0 0 0 0 0 2
    26
    27 SUS Vis @ 210°F 49.8 49.6 48.6 53 49.0 48.3 49.3 48.1
    28 cSt Vis @ 100°C 7.21 7.15 6.85 8.19 6.97 6.76 7.07 6.69
    29 Flashpoint °F 390 330 365 400 375 390 385 395
    30 Fuel % <0.5 2.8 1 <0.5 <0.5 <0.5 TR <0.5
    31 Antifreeze % 0 0 0.0 0.0 0.0 0.0 0.0 0.0
    32 Water % 0 0 0.0 0.0 0.0 0.0 0.0 0.0
    33 Insolubles % 0.3 0.3 TR 0.3 0.1 0.3 0.4 0.4
    Updated 10/18/2017
    #53 szgabor, Oct 18, 2017
    bisco and m.wynn like this.
  14. bisco
    52,286
    6 year member and 2 posts about acronyms? wow, acronyms must really burn your shorts.(n)
    Grit likes this.
  15. Prodigyplace
    12,628
    11,808
    Central Virginia
    Just either too lazy to search or too offended to look in the Newbie forum.
    PriusChat Glossary | PriusChat
    Grit and bisco like this.
  16. szgabor
    994
    175
    Oceanside NY
    See bellow the updated report including the most recent data. Las oil change 21 April 2018 @74650 went a little bit early ... another fill up or two weeks left but better early than late :)
    I am not totally sure about this the service guys gave so little oil half the test couldn't be done, and the oil seems contaminated. Perhaps forgot and filled it from the pan ?? ... and the result is funky ... but I will post it so the record is there
    Here it is.
    Mile on car 74650 65824 58994 50000 40885 30128 20000 10051 5400
    1 Mile on Oil 8826 6830 8845 10000 10756 10k 10k 5k 5.4k
    2 Date 04/21/18 09/07/17 02/02/17 06/04/16 09/17/15 05/09/15 08/30/14 10/07/13 05/10/13
    3 Oil type Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20 Syn 0w20
    4 Oil brand Toyota Toyota Toyota Toyota Toyota (Toyota) (Toyota) (Mobil 1) (Factory OEM)
    5 Make Up Oil qrt 0 0 0 0 0 0 0 0 0
    6 ALUMINUM 5 4 4 5 3 4 7 6 8
    7 CHROMIUM 0 0 0 0 0 0 0 0 0
    8 IRON 15 5 9 7 5 5 9 7 17
    9 COPPER 13 1 1 1 1 1 3 12 62
    10 LEAD 0 0 0 0 0 0 0 0 0
    11 TIN 1 0 0 3 0 0 0 0 0
    12 MOLYBDENUM 70 41 37 36 40 46 44 71 100
    13 NICKEL 0 0 0 0 0 0 0 0 0
    14 MANGANESE 1 0 0 0 0 0 0 0 2
    15 SILVER 0 0 0 0 0 0 0 0 0
    16 TITANIUM 0 0 0 0 0 0 0 0 0
    17 POTASSIUM 0 0 2 2 0 6 0 1 0
    18 BORON 8 5 8 2 7 14 20 91 2
    19 SILICON 50 8 8 9 8 6 17 47 206
    20 SODIUM 6 5 6 6 9 5 5 4 5
    21 CALCIUM 2090 2097 2021 2103 2301 2712 1974 2315 1981
    22 MAGNESIUM 83 18 13 9 11 15 14 38 13
    23 PHOSPHORUS 721 598 560 513 564 762 487 823 687
    24 ZINC 844 665 631 616 683 876 596 916 769
    25 BARIUM 1 0 0 0 0 0 0 0 2
    26
    27 SUS Vis @ 210°F - 49.8 49.6 48.6 53 49.0 48.3 49.3 48.1
    28 cSt Vis @ 100°C - 7.21 7.15 6.85 8.19 6.97 6.76 7.07 6.69
    29 Flashpoint °F - 390 330 365 400 375 390 385 395
    30 Fuel % - <0.5 2.8 1 <0.5 <0.5 <0.5 TR <0.5
    31 Antifreeze % 0.0 0 0 0.0 0.0 0.0 0.0 0.0 0.0
    32 Water % 0.0 0 0 0.0 0.0 0.0 0.0 0.0 0.0
    33 Insolubles % 0.2 0.3 0.3 TR 0.3 0.1 0.3 0.4 0.4
    Updated 05/2/2018
    #56 szgabor, May 2, 2018
    tochatihu likes this.
