PRIUS HATERS !!!
Discussion in 'Gen 3 Prius Main Forum' started by Topp Cat, Jun 18, 2015.
  1. Topp Cat
    Topp Cat Member
    71
    66
    Yes ! I am a former Prius hater! Now I have a 2015 Prius five. Man these are made Cheap really cheap! I love the MPG! 50- 55 highway 42- 56 city . Spend hours sound proofing and fixing rattles. Just installed Cusco frt sway& get lower brace.
    sfv41901 likes this.
  2. law
    law Member
    188
    33
    CA
    Welcome! All cool kids drive Prius and get all gorgeous ladies!
  3. bisco
    52,258
    congrats! i don't find them that cheap. i wouldn't mind a little quieter, but i suppose it depends what you came out of. i came out of a taurus, it wasn't any better.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Hmmm, OP has a liftback or a c ?
  5. MADPolo
    MADPolo New Member
    Tampa, FL
    Yeah, I came from a 2005 4x4 Ford Ranger, so my prius is a dream compared to that, lol.
    Koreaneugene, Burna J and bisco like this.
  6. CR94
    CR94 Senior Member
    2,735
    1,195
    Northwestern S.C.
    It's considerably less noisy than any previous car I've had, under most circumstances. It's also the most expensive, even allowing for inflation.
  7. Mendel Leisk
    41,808
    D.O., coming from a creaky Civic I still get to drive sometimes.
    To be fair, the Civic took a few knocks..., the Prius has too tho.
    Priusguy78213 likes this.
  8. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Bought a Prius instead of a LS600h and calls it cheap. SMH ;)
    #8 Avi's Advanced Automotive, Jun 19, 2015
  9. a_gray_prius
    2,927
    783
    IL
    Our Prius has been the cheapest car we have ever owned to run (mandatory dealer visitation notwithstanding - my biggest gripe with the car)
  10. Mendel Leisk
    41,808
    You can DIY, if you've got ways 'n means. They don't make it easy though, no oil change instruction in owners manual, for example.
  11. bisco
    52,258
    no reason for hate, it's like gun owners, don't tread on me.
  12. a_gray_prius
    2,927
    783
    IL
    Nah, you need a techstream if you want to do some jobs like brake fluid flush (properly).
  13. ChapmanF
    18,434
    That's what a lot of DIYers on this forum are using.
    -Chap
  14. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Yeah, you can tell they'd really prefer that you take your Prius to the dealer for EVERYTHING; no detailed info about maintaining it in the manual. Well other than "take it to your nearest Toyota dealer for service". But basic maintenance is really not that difficult to do if you don't mind getting down on the pavement and getting dirty. Oil changes are actually VERY easy and quick. Even w/o a lift, you can jack up the car, slide some jack stands under it and get in an oil change pretty quick. About as easy as my 2005 Honda Civic was to change oil in; I traded it for the Prius. Even the transmission fluid is really quick and easy to do. The manual says check only until 100,000 miles but nothing about changing before then?? Yeah, I'll be changing my at around 60,000 miles. Better safe than sorry. And just a matter of taking off a few plugs; drain plug and the fill plug.
    You can get LOTS of reliable, easy to follow info from just doing a youtube search.
  15. Toasty
    Toasty Junior Member
    35
    Chattahoochee Hills, GA
    what does the front sway bar do? (or helps with)
  16. ChapmanF
    18,434
    Sway bar.
    -Chap
