I'm curious; if the engine runs out of oil, will it shut off automatically?
Discussion in 'Gen 2 Prius Technical Discussion' started by herqulees, May 22, 2015.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    And compared to 40 years ago they're right.
  2. uart
    uart Senior Member
    4,220
    1,211
    Australia
    With 5k mile oil change intervals that's probably feasible for 99.9% of owners during the engine warranty period (3 yr).
    For higher mileage Prius and longer oil drain intervals it's definitely not something to aspire to do.
  3. frodoz737
    frodoz737 Top Wrench
    4,696
    2,495
    33
    Yea...I believed everything the sales guy told me too. :LOL:
  4. Patrick Wong
    18,204
    6,505
    Goal #1: Customer minimizes personal involvement with auto maintenance, which furthers the next two goals:
    Goal #2: Maximize service department revenue because the ignorant customer has to accept the dealership service writer's word about what maintenance and repair the car requires
    Goal #3: Limit vehicle service life to not much beyond the manufacturer's warranty period, to encourage new car sales
    alekska, valde3, brucebee and 3 others like this.
  5. Mendel Leisk
    41,406
    We are 6 mo or 8000 km interval. But still.
  6. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    uart,
    This leads to another interesting story regarding oil consumption and obliviousness.
    In April I had an opportunity to buy an '08 with 155k from a good friend who is an every 5k miles dealer service guy. We had been planning for about 3 years to let me have a first crack at it before he did his customary trade-in thing, as he's doesn't like the hassle of selling off vehicles himself. When he let me know it was time, my only question to him was how much, if any, oil it burned. His answer was that when the reminder light came on he took it to the dealer and had it changed. The light had happened to just come on, though, and he said he'd pull the stick and let me know. He couldn't get the dip stick out. It was stuck enough that he needed a shot of WD-40 to break it free - no joke. Admittedly, the dip stick had never been pulled since he drove it off the lot at purchase. The good news, it was only 1/4" down on the stick.
    Mike..
  7. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Well before any serious engine damage should occur the car should warn you with a low oil pressure indication.
    Never ignore an oil pressure warning!
  8. bisco
    51,897
    looks like the goal is in sight, but...
  9. bisco
    51,897
    ...what if you can't pop the hood because you left the dome light on, the 12v is dead, your locked out and don't know there's a key in the fob, because your parents forgot to tell you?:p
  10. frodoz737
    4,696
    2,495
    33
    That's when you get that..."Hey uh Dad"...phone call.
  11. bisco
    51,897
    yup. if the cell phone bat isn't dead as well.
  12. frodoz737
    4,696
    2,495
    33
    That will teach him to put the damn thing down once in a while...and not leave the lights on too. ;)
    SageBrush likes this.
  13. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    a chevy volt in a prius chatroom?
    is that allowed?
  14. Beachbummm
    1,160
    392
    "I'm curious; if the engine runs out of oil, will it shut off automatically?"
    yes and may never start again...
    "umm hun how long has the oil light been on and why is their a sticker over it??"
    if you cant pump your own gas
    check the oil weekly
    and change a tire when needed
    sell the car and get a bus pass
  15. frodoz737
    4,696
    2,495
    33
    Not to sound sexist, because I'm not, but many years ago that's what used to be called...Female Basic Car Skills 101.
  16. Beachbummm
    1,160
    392
    most men now cant figure it out either...todays man has become pathetic and dose not want to get his hands dirty.. my 35 yr old neighbor hires handy men for everything and always complains he's broke..paid someone yesterday $75 to replace 2 sprinkler heads and flush the rest...
  17. Patrick Wong
    18,204
    6,505
    Well, the car should have had 30 oil changes since it was new. Hopefully the dealer tech who changed the oil checked the oil level on the dipstick before releasing the car - or would that be too much to expect??
    Also, since you and your friend have no idea how much oil was added by the dealer tech when the oil was changed, the fact that the oil level is currently 1/4" down from the top dimple after 4,500 miles does not necessarily mean that little or no oil was consumed. For example: if the oil started at 3/8" over the top dimple, around 3/4 or 1 quart would have been consumed... In any event, if you did buy the car, then good luck and you can tell us under more controlled conditions what the actual oil consumption is.
    #37 Patrick Wong, Jun 21, 2015
  18. Mendel Leisk
    41,406
    Funny, I'm almost reluctant to check oil immediately following an oil change. I'll run the engine, and then yeah, I do check it, but pay it little credence. It always seem to read about a pint low, even though I've put in the proscribed amount, which I know will put it on the full mark. Plus it's so clear/clean, hard to read.
    I'll basically make sure the oil somewhere between the marks. Then check a few days later, and it's always on the full mark then.
    I suspect this might be the cause of dealership overfill: they don't have the luxury of letting the car go with oil level looking lowish. But it does seem to be some lag, before the level settles down in the sump.
    valde3 likes this.
  19. Patrick Wong
    18,204
    6,505
    This is true, and that is because the new oil takes a while to move from the cylinder head area down to the crankcase. I agree that checking the oil level immediately after doing an oil change will result in a reading somewhat below the actual oil level.
  20. Mendel Leisk
    41,406
    Fresh added oil seems worse though. I'd guess when you pour 4 plus litres into the valve cover area, some of it hangs up in there, 'till the car's had a decent drive.
    Subsequently, say a week later, I can check oil soon after shut down, say within a minute, and it's as high as it's going to get. Well nearly.
