Difference in EV mileage between Base and Advanced?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Greg_M, Jun 19, 2015.
  1. bisco
    52,295
    start by jacking up the car and spinning the wheels. alternatively, feel the temp diff between the two cars after the full ev drive. maybe call the dealer and see what was going on. and finally, stop both cars on a hill and see how far they coast.
    52,295
    and chazz is right, in his correction, if the engine oil level is affecting your ev distance? you've got bigger fish to fry. although, i suppose the weight of the extra oil could be bogging you down.:p
  3. Mendel Leisk
    41,830
    Good catch. OP could try: drive both cars for a decent stretch, pull over, feel the rims, see if one feels warm, the other not.
  4. Greg_M
    Greg_M Member
    151
    35
    NC
    Not that it makes a difference but it was 12k miles over the last 9 months. I'll call the service department next week but I doubt I'll get a straight answer out of them. After all, the work was done at the dealership that sold me the car and if there is something wrong then I seriously doubt they'll admit to selling me a car with a known problem.
  5. bisco
    52,295
    toyota dealership? may have to get toyota involved. i wonder if regen could be somehow involved?
  6. Greg_M
    Greg_M Member
    151
    35
    NC
    Toyota dealership
  7. bisco
    52,295
    well, if they stonewall you, i would get an email to toyota customer service, with a copy of the brake fluid work. maybe nhtsa too, brakes are a safety item, needless to say.
  8. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    An infrared thermometer would be great for this too. They're only ~$20 and will pick up smaller variations in temperature than people can.
  9. Greg_M
    Greg_M Member
    151
    35
    NC
    Good idea and I've got one
    Job number on the brake fluid was MOC06D. Anyone know what that code means?
  10. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That must be dealer specific. Are there any trouble codes listed?
  11. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    From all the details Greg gave, it seems likely to be a battery problem, maybe the 2012 battery was abused?
    Before going into other routs checks I would check the amount of charge each battery is getting with a kWh meter, this, however, should be done from a same starting point (say, 4 bars on the HV battery icon) to full charge.
  12. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Might be a bearing issue. On my Gen II Prius, my bearing failed, driver's side. The noise is very subtle but I was able to pick up the noise but my wife who claims to have better hearing than me said she couldn't hear a thing nor could the mechanic who was riding with her. It did turn out the bearing was bad.
    Or a maybe the previous driver drove it hard and the accumulated mileage at the long term advanced speed is weighing the average down. Toyota does protect the battery with rather cautious algorithms. Best way to test this is to pull the negative lead on the 12V auxiliary battery. But it erases all of your stats.
  13. Greg_M
    Greg_M Member
    151
    35
    NC
    Bought a watt-a-meter and here are the results.
    I ran the EV part of the battery down and then let it sit in the driveway with the A/C on until the engine started. Shut it off right away and then plugged it in. After the first one finished charging I then ran the A/C in the second one until the engine started, turned it off, and then plugged it in. Both cars engaged the engine as soon as the battery dropped to 2 bars.
    2013 Base plug-in
    Charged for 2:27 and 3.11 kWh
    2012 Advanced plug-in
    Charged for about the same time and took more than 3 kWh
    I checked on it and the meter indicated 3kWh but it was still charging. Checked the dash and it indicated another .5 kW needed at .5hrs. 10 minutes later I went out and the charge was complete but the stupid meter had reset to zero. Bottom line is that they took about the same charge.
    Chazz8 likes this.
  14. bisco
    52,295
    sounds like the battery is fine, leading back to the brakes...
  15. Greg_M
    Greg_M Member
    151
    35
    NC
    If there is something with the brakes then it would noticeably affect my mpg when running in hybrid mode after using the EV miles. Now I haven't had this car long but I don't believe that my mpg are being affected and if they are it's by a very small amount.
    Question:
    Is there anything other then the battery (which I think I ruled out) that could be lowering my EV miles per charge but having little to no effect on my mpg in hybrid mode?
  16. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Low probability answer; overheating inverter due to defective inverter or inverter cooling system. Could be checked with Torque App or ScanGuage II to check operating temperatures of crucial components.
  17. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I have the Eagle L/S tires on my Leaf, and they are only very slightly lower in rolling resistance than the OEM Ecopias were (about 4.3-4.4 m/kwh in warm weather, vs 4.4-4.5 for the Ecopias). I think the Eagles are rated lower overall mainly because of reports of hydroplaning in heavy rain at highway speeds. (Me, I always slow down in heavy rain!) Still the difference in rolling resistance is probably more than the tires, so I agree that the brakes, bearings, etc need to be investigated. I'd also make sure the car was never in a flood.
    SAronian likes this.
  18. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    It is becoming more and more challenging. It seems that while driving in EV, part of the energy drawn from the battery is leaking away in one way or the other. Maybe they have to check the electrical circuits and motors involved.
    Electrical energy leaking away usually produces heat, so there may be parts in the car that become more hot than normal; this may even produce some smell.
    P.S. More than 3 kWh for full charges are quite good results for the batteries.
    #58 Jan Treur, Jun 22, 2015
  19. Greg_M
    Greg_M Member
    151
    35
    NC
    My driving has raised the guess-o-meter on the car when it's at a full charge. I do believe that I've seen a slight increase in actual EV miles since I bought it a week ago (I've driven a lot of EV miles and charged it more than once per day). The last 4 months of the last owner the car was driven about 1350 miles per month with an avg mpg of slightly over 50. It's possible that the previous owner didn't drive it for mileage.
    Since pulling the neg lead is an easy and quick experiment I'll go ahead and do that this morning.
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Why doing this? What will it achieve? Certainly nothing regarding the actual EV miles you are reporting (you are reporting actual EV miles in this thread aren't you?).
