NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by seilerts, Jan 12, 2012.
  1. bisco
    52,024
    you're all set, the issue was completely resolved with the commencement of the 2013 model year production.
  2. gliderman
    gliderman Active Member
    751
    225
    How was it resolved?
  3. bisco
    52,024
    well, that's the question, isn't it?
  4. henry holder
    henry holder New Member
    satsuma,al
    2011 Prius Alpha
  5. bisco
    52,024
    i don't think so.
  6. Tande
    Tande Active Member
    540
    322
    Mich.
    Nor do I! ..........;)
  7. Slamzilla
    Slamzilla New Member
    Mine did it a week ago, 2015 Prius four with 2700 miles on it. Dealer found no codes and acted like they have never heard about it before.
  8. bisco
    52,024
    liars!:mad: welcome to priuschat.:)
  9. frodoz737
    frodoz737 Top Wrench
    4,708
    2,510
    33
    ...but I thought they had the -5 intake now. :ROFLMAO:
  10. orenji
    orenji Senior Member
    5,887
    3,488
    What noise? :D
  11. ETP
    2,802
    1,170
    Auburdale FL
    What hump?
    mrlebop and bisco like this.
  12. Former Member 68813
    3,524
    983
    US
    Believe it or not, it just happened to me in a non-hybrid car, RAV4.
    I pulled it out of garage in AM to make room for another car i worked on. it run for 10 seconds and sat all day outside. the car was very hard to start at the end of the day and rough idle with misfiring.
    i had only 2 instances of that in prius in 70,000 miles. both times, the same thing, engine run short time and then it set for hrs.
    the only thing different, it feels more than knocking due to the feedback between ICE and electric motors in a hybrid.
    either way, it's an user error.
    orenji likes this.
  13. ETP
    2,802
    1,170
    Auburdale FL
    yep, lack of fuel. Too lean! But we be ok even if we do not get better.
  14. minnyprius
    minnyprius Member
    141
    45
    Twin Cities
    I'm so grateful for this forum... I just bought a 2012 PiP with 50K on it... it's about 15° this morning, and the motor sounded so broken... thankfully, I have been reading posts on here for years and was familiar with the problem. I waited patiently, and after about a minute, it stopped and ran silky smooth all the way to the bus station. I'm gonna call my local dealer to let them know about it, but doesn't sound like there's much that will be done. I'll have to look into how to clean the EGR valve...
  15. bisco
    52,024
    that's a crummy way to start with your new pip! make sure you don't power down while the engine is running.
    minnyprius likes this.
  16. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    I agree, if you've just turned it on after X number of hours sitting and the engine starts, let it run at least a couple minutes before shutting it off. That should avoid the moisture buildup in the engine that causes the knocking.
    On a related note, I've noticed my PiP will start the engine no matter what if it's below about 30 degrees. Above that it will stay in EV when turned on, if charged. I've also read somewhere that the engine will run if so many days have elapsed since last warmup cycle, I believe it's 2-3 days.
  17. bisco
    52,024
    124 miles.
  18. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Ahh, is that what it is then? Cool.
    iPhone ?
  19. minnyprius
    minnyprius Member
    141
    45
    Twin Cities
    Great to know these things! Thank you! I was having too much fun driving in EV mode while running errands, that it had been a while since the motor had a chance to be warm, and good to know about the below-30-degrees deal... I'll let it do its thing instead of trying too hard to stay in EV...
  20. trentofdestiny
    1,104
    227
    Harrisburg, PA
    You're welcome. I *always* have some charge when at home, even if not full, so that's how I noticed the temperature thing. I don't go 124 miles without running the engine anyway so I did not know that one.
    Staying in EV is/was more of an issue with the standard Prius since you have about 1.5 seconds to tap the EV button after turning the ignition on to attempt to stay in EV.
    And it didn't always work.
