  1. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    Lol, I know Joe, it's tough with a toddler and a 1 year old. Family comes first, however I finally found some time late at night with all the tools.
    I did the front Coilovers and it took me 4 hours just making sure I was doing everything right. Will have to finish the rear later this afternoon. Here are a few shots. I lowered it to about 1 and a half fingers gap space in the wheel wheel. I spent a lot of time measuring and comparing OEM to stock lol.
    Sorry for the cruddy pics, it's 5am and I'm sleepy haha. I'll put the new wheels on later.
    [​IMG][​IMG]
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Starbrand, orenji, nedear88 and 9 others like this.
  2. ratedK
    ratedK Junior Member
    Indianapolis, Indiana
    After getting the OGS push button shifter, I didn't like the nighttime 'always on' single LED light in the ceiling console. It produced a glare off of the shifter that I found irritating. With some simple soldering skills, it is pretty easy mod. I found the two closest solder points on either side of the LED module, then used a dremel to sever the trace on the board between them. I had originally planned to run the wires down to an empty switch plate down near my knee, but decided against it when I found room to mount the switch right next to the light.
    slowpriusj, Starbrand, ncases and 2 others like this.
  3. Red Salamander
    Red Salamander Junior Member
    I removed the $tealer/Dealer logo from the derrière without a scuff to the Barcelona finish. A small thing to start with perhaps but it was causing me anxiety to have my vehicle serve as an advertisement.
    Priusguy78213, Dylan Doxey and orenji like this.
  4. ratedK
    While I was modding the LED light (see previous page) I noticed that there was some usable empty space in the area between the sunglass holder and the windshield. I had been having an issue with my so-called "permanent" radar detector mount staying adhered to the windshield. This empty space seemed perfect for said radar detector, so I went to work. I had to dis-assemble the radar detector in order for it to fit within the space available. With my handy dremel tool, a few hours, and lots of patience, I made it fit (and made it look good!). I had to cut a square out of the front of the panel to allow the detector to protrude through the front, then re-used the panel I had cut out to cover the exposed circuit board. If you notice that the screws on the board change, good eye. I had replace the original screws with some from an old laptop because the heads had a slimmer profile.
    FYI, it's an Escort SmartRadar. It does not have a display on the unit, which made this possible. It connects bluetooth to my phone, and has an external display as well. The last picture shows where the external display is mounted to the right of the phone.
    #8024 ratedK, Jun 24, 2015
  5. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
    Nice job! I used that same spot for a Homelink door opener module.
    Dylan Doxey and ratedK like this.
  6. ncases
    ncases Senior Member
    609
    672
    Chicago
    Nice one bro. If it was me I might have just plug in an earplugs or some playdough to that little hole.
    ratedK, xliderider and Xterra72 like this.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    I would have first tried to install a filter to "soften" the light coming from the LED.
    ratedK likes this.
  8. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Nice. I've got the same OEM wheels. Was tempted to change them out also but wanted to stick with the lower weight. Those new ones look sharp though. Was wondering where you got your tail lights. Looking to maybe change the OEM ones out in the Gen III I have.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yep....I'm The 2nd owner & I've put about 100k in it
    Sentfrmy S980G using ptalk
    Thought I would share a post from my wife about me gettin the Prii back
    Seans Facebook Post
    St fro my S980 4G usig Tapatal
  10. Accordlayingkit
    Accordlayingkit Senior Member
    1,618
    1,748
    377
    Colonial Heights, Va
    Maybe a screenshot for us that don't have Facebook??(facebooks trouble) lol
  11. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Received my Valenti tail lights from @munkeeboi today, can't wait to install them this weekend. Does anyone know the thread on the removal and installation of the tail lights? Lemme know, Cheers!
  12. Accordlayingkit
    1,618
    1,748
    377
    In my thread page of my signature ...page 1 first post
    TopRamen likes this.
  13. TopRamen
    307
    578
    Fremont, Ca.
    Thank you sir!
    Accordlayingkit likes this.
  14. Accordlayingkit
    1,618
    1,748
    377
  15. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Your came with the white plastic connector and black connector on the side? When I got it from twptrade.com my did not come with it. I had to move from old tail light over.
    Good video on install
    Priusguy78213 and TopRamen like this.
  16. Accordlayingkit
    1,618
    1,748
    377
    @munkeeboi apparently left them on there when @TopRamen got them because i had to transfer mine as well
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Setfrm m 980 4 igTaatk
  18. Accordlayingkit
    1,618
    1,748
    377
    It would have been pretty hilarious is she hash tagged #gspot instead(if she only knew huh) hahahaha
    So whats next up for ya besides the steering wheel??
    #8038 Accordlayingkit, Jun 25, 2015
    sfv41901 likes this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Gotta finish the rear door SKS
    Set fmmy VS90 4G usig Tapatlk
    Accordlayingkit and torparts like this.
  20. apt5020
    881
    1,294
    Prius City, CA
    Master, is the seat painted two tone? I don't recall if it was last time.
