Purchasing a Used GenII - At what point should I let miles be a primary concern?
Discussion in 'Gen 2 Prius Main Forum' started by bryanv, Jun 24, 2015.
  1. bryanv
    bryanv New Member
    22
    Indianapolis, IN, USA
    2002 Prius
    Repairing my Gen 1 would cost half of the price of buying a used Gen II with higher mileage. So here I am.
    I have a few options right now -- all comfortably within budget. As in, not at the top end of my budget, so I'd be able to afford the car. Hopefully *crosses fingers*
    I know what to look for on the Gen I's now (trial by fire) but I'm wondering how different is that for Gen II's.
    Any help / tips / pointers would be very welcome. I'll be driving both of these tomorrow.
    52,074
    impossible to answer. if you're non carb, than your hybrid warranty is 8/100, so that's one concern. after that, they tend to start having problems all the way along as you build miles, especially the battery. but the percentages grow, and most are trouble free for 150k or so. many for 2-300k, but we have no actual numbers. all the best!(y)
  3. bryanv
    bryanv New Member
    22
    2002 Prius
    One is an 04 with 245k, new battery (1 year warranty -- I assume it's a rebuilt)
    Should this be setting off alarm bells?
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    Anything with a rebuilt battery sets alarm bells off.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    New batteries from Toyota only have a one year Warranty.
    bryanv likes this.
  6. bisco
    52,074
    at 250k, you should be fully equipped to do serious maintenance, or be ready to pay for it.
    bryanv likes this.
  7. bryanv
    bryanv New Member
    22
    2002 Prius
    Ah Hah! Thanks for the input. The 245k vehicle is probably out then. (I'm not sad about that)
    I'll be looking at a 2006 base model with 137k on the odometer. At that mileage, what should I be looking for?
  8. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    Apart from all the normal stuff you would check on a regular gas powered car (fluids, oil, test drive, service history, carfax, etc), check the inverter reservoir is at the full mark and that you can see turbulence detected when the car is ready.
    Using your newly acquired, M-VCI, if they will permit you, you can do a basic check on the HV, to see if it is exhibiting any thing unusual. See this link for how to do this:
    Predictive Battery Failure Analysis For The Prius Hybrid | Art's Automotive
    hope this helps.
    [Edit] While you have the M-VCI connected, do a health check and see what codes, if any, it has. It may not show anything, especially if someone with no morals has been in and cleared them. Not to worry, anything serious should come back on the test drive.
    #8 dolj, Jun 25, 2015
  9. bryanv
    bryanv New Member
    22
    2002 Prius
    That totally helps, thanks!
    These Gen II's move like hotcakes when they're in good shape. Two of the three I was going to look at this morning sold last night.
    I drove the one with 245k on it -- I'm not buying it, new battery or not, at the price they want for it. The HV system doesn't scare me as much as the ICE, drive train & associated parts at 245k... If it were priced a few thousand less, I may be willing to take the gamble, but as is, no.
    Driving that car (and inspecting it) confirmed my suspicions on my current Gen 1 though. Bad coolant pump, bad power steering, bad master cylinder. :-( Such a shame. 44.5 MPG was the average over the last 4k miles on that car.
  10. bisco
    52,074
    when i look at a used prius, (which i never do:cool:) i like to reset the average mpg's, take it for a good long test drive under various conditions, and see how it does.
