A good way to clean out grungy air-inlet vents?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by davide, Jun 25, 2015.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I have to park outside, & haven't been going to the car-wash frequently, so a mix of decayed leaves, twigs, bird doo & dirt has accumulated in the foot-long air-inlet vents just below the windshield (not the wider set of vents closer to the hood) . So today I used a tweezers to clean out quite a bit--pouring on some water helped--but some grunge still remains down in the vents.
    My plan: go to the car-wash & ask the guy with the high-pressure hose to spray into that foot-long vent area for a good 5-10 seconds to flush it out. Is this a good idea?
  2. Mendel Leisk
    41,925
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Don't think that will help. There was a post on Priuschat on how someone took the plastic cover off to clean the screen. I would try blowing it out with compressed air or as you have been doing it with tweezers and maybe a paint brush to clean it out.
  4. ufourya
    ufourya We the People
    1,258
    336
    42
    I would vacuum. It seems to me you'd want to get the debris out, not force it in.
  5. bisco
    52,399
    vacuum and plucking. maybe cover them when parked?
  6. ETC(SS)
    7,365
    Concur.
    +1
    Bisco has the right approach.
    Clean, then find a way to cover the vent.
    You might be able to loosen debris with a clothes dryer brush.
    Buy a sun-shade and stop parking under trees.
  7. orenji
    5,887
    3,488
    Vacuuming does not work, tried it already. The screens are down to low and too wide to make any good suction.
  8. Mendel Leisk
    41,925
    Press some masking tape onto the screen, then peel off?
    Then, there's this stuff, hehe. Might backfire tho:
  9. bisco
    52,399
    ghostbusters?
  10. Mendel Leisk
    41,925
    Hey, it's "Swiss Formula". :rolleyes:
  11. bisco
    52,399
    swiss slime? i'll stick with their cheese.:p
  12. Mendel Leisk
    41,925
    Well, it looks like radioactive yogurt...
  13. bisco
    52,399
    exactly.
  14. Mendel Leisk
    41,925
    I tried the CyberClean, actually worked quite well, and didn't stick or get hung up in the mesh.
    Before:
    Not much, but anyway.
  15. bisco
    52,399
    mendel, you've been slimed!:eek:
  16. orenji
    5,887
    3,488
    How about Play Do, that may work too!
