2015 Prius Three, not III, Android 4.4.4 w/oem camera working.
Discussion in 'Gen 3 Prius Audio and Electronics' started by tangokim, Jun 26, 2015.
  1. tangokim
    tangokim Member
    35
    39
    Just want to share my new HeadUnit mod with all your fine folks here. I got the unit from aliexpress and camera hardness from ebay. So far everyting working great.
    Cons:
    1.Radio signal some what ok but sometime fuzzy( dont really use radio anyway, internet radio for me)
    2.Dont leave your unit in the bright sunlight (97f)for long time because after that the unit will turn on but nothing function unit cool down(like 5-10 mins). I used sunshade cover so this will eliminate that issue. I think even if you put your phone to the sun for long time will make it act like this i think.
    Pros:
    1. Everything look and works great.
    2. Sound sound great.
    3. stock look and oem camera.
    4.cheap upgrade with everything loaded.
    Head unit from aliexpress. Speak to coco and use my username tangokim to get discount.
    Wholesale Product Snapshot Product name is For toyota PRIUS 2 DIN car dvd GPS Android 4.4 1024*600 with WIFI 3G GPS Bluetooth 1.6Ghz stereo Car radio Capacitive screen
    Unit: $271+91 shipping
    1.6x4 core: $35(optional)
    1024x600: $29(optional)
    Camera Hardness. Speak to brian for installation support and other question.
    Backup Camera to Aftermarket Headunit Retrofit Adapter Harness for Toyota Subaru | eBay
    So everything come out to be $485.
    #1 tangokim, Jun 26, 2015
    eunique and Sergiospl like this.
  2. zigzampow
    zigzampow Junior Member
    Charlotte, North Carolina
    Steering controls work? Is it fast and snappy? I was considering buying one of the android auto units but this may be a better bang for buck
  3. tangokim
    tangokim Member
    35
    39
    The steering seem the same to me as it was hooked to stock unit. At this point I'm very happy to get all this working
  4. ncases
    ncases Senior Member
    609
    672
    Chicago
    Does your trip, temp functional on your steering wheel?
  5. tangokim
    tangokim Member
    35
    39
    Yes. That never change and will not mess with.
    ncases likes this.
  6. ncases
    609
    672
    Chicago
    Hi @tangokim I was wandering maybe you can guide me where you tapped the reverse in to the prius reverse harness. Thank you.
  7. tangokim
    tangokim Member
    35
    39
    Do you have oem camera? Because i uses oem camera with the harfness from ebay link above. That harness create a step down power to the camera and only required a few steps to get the camera n everything works
  8. ncases
    609
    672
    Chicago
    I have the aftermarket 12v rear camera installed. The unit has a reverse-in line that triggers when shifted to reverse. If you don't mind how did you tap the reverse-in wire to the head unit backup camera harness. I noticed that you tapped your (reverse in) to the purple wire. I'm just wandering which pin on the connector that the purple wire was coming from. Thanks.
  9. tangokim
    tangokim Member
    35
    39
    The purple cable came from ebay conversion kits which power step down to the oem backup camera
  10. ncases
    609
    672
    Chicago
    Have you noticed any garbled sound when on high speeds?
  11. tangokim
    tangokim Member
    35
    39
    Not really. Only issue is the radio getting fuzzy over time but a quick turn off n on fix it.
  12. SorinMS
    SorinMS Junior Member
    Romania
    You use the OEM GPS antenna? It needs some modifications?
  13. Tom Payne
    Tom Payne New Member
    mountain view
  14. BigBear2010
    BigBear2010 Member
    156
    65
    Does you head unit include the option 1.6x4 and 1024x600?
    Will this unit has the same options like your?
    Better New Android 4 4 4 OS 8" Prius 2009 2013 Player Car DVD DVR WiFi 3G Gifts | eBay
    #14 BigBear2010, Jul 13, 2016
  15. afpri
    afpri Hemi-Hybrid
    27
    Maryland
    Thanks, great post! Congratulations on getting good it working!
    I bought the same unit. I love it. However, I have 2 issues. The steering wheel controls plug from the new stereo (the one with 3 wires), doesn't fit the car harness. So, is that why you cut and spliced it? If so, how do I know which wires to splice. They are labeled Key 1, Key 2, and ground. I have 3 plugs from the car that are not being used. One is the steering wheel controls(not sure which one though). The other 2 I don't know the function but one harness has a lot of wires and may control vehicle settings? You said at 3:10 in youtube video you bought another harness? Is that what I am missing? Thanks for your help!!
