Need help from you..
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Sulara Perera, Jun 28, 2015.
  1. Sulara Perera
    Sulara Perera New Member
    Colombo, Sri Lanka
    Pls anyone know what this error code describes..?
    51,846
    welcome! looks like japanese? could it be your maintenance warning for oil change?
  3. Mendel Leisk
    41,334
  4. bisco
    51,846
    thanks, much better.
  5. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    Isn't there a way to change the display language?
  6. bisco
    51,846
    google?
  7. Patrick Wong
    18,200
    6,500
    OP probably bought a Japan domestic market vehicle, and it would be easier for him to learn Japanese than to change the display.
    CR94 and YukYukLee like this.
  8. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Asked a coworker to translate just now:
    "Hybrid system check"
    And this is the phrase plugged into Google translate:
    So it's akin to the ubiquitous Check Hybrid System message on our USDM Prii.
    Patrick Wong and bisco like this.
  9. bisco
    51,846
    start with the 12 volt?
  10. Sulara Perera
    Colombo, Sri Lanka
    It says "Check Hybrid System"
  11. Sulara Perera
    Colombo, Sri Lanka
    Could it be The Main Battery or the 12v?
  12. xliderider
    8,140
    3,276
    Honolulu, HI
    How old is your 12v auxiliary battery? Do you have a multimeter or voltage tester? Measure the battery voltage at the battery terminals or underhood jump terminal and ground.
  13. Patrick Wong
    18,200
    6,500
    1. What warning lights appear on the dashboard and on the multi-function display (if any)?
    2. If there are any lights on, take a sharp photo and post.
    3. Measure the voltage of the 12V battery and report your findings when the car is IG-OFF, IG-ON (when all warning lights are on), and READY.
  14. Mendel Leisk
    41,334
    We got a "Check Hybrid System", with our 3rd gen. Dealership found (and dismissed) codes relating to sensors in brake system, losing communication. I noticed a momentary loss of braking, just before warning came on. No repeat since.
    Guessing CHS warning can come on for multiple reasons?
  15. bisco
    51,846
    probably, there's a lot of hybrid in these hybrids.
