Do I have to replace that Cabin Filter!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Littlei, Jun 30, 2015.
  1. Littlei
    Littlei Junior Member
    Chicago, IL
    Last time I went to the dealer because that damn light went on they just rotated my tires and charged me $39.99! Said it wasn't time for an oil change. They wanted to replace my cabin filter$$ but I said no as what the heck is that necessary for?! Do I really need to replace it? Other cars I had didn't have cabin filters. :oops:
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yes, you really should clean it out periodically, and change it out when necessary. Buy it on your own and change it yourself, there are YouTube videos on how it's done.
    The filters run about $10 to $15 on Amazon.
    jzchen and Priusguy78213 like this.
  3. Mendel Leisk
    41,850
    I've yet to change the cabin filter, at 53K kms. I've looked at it 2 or 3 times, blown the dust out. I think it depends on location a lot though.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I replaced the filter myself and took Prius in for service the next day. The damn dealer called and told me the filter needed to be replaced. You can't trust them when they can make a quick $20.
  5. bisco
    52,335
    yes, at least inspect and change if necessary. fairly easy diy and you can grab one at the dealer if you need it. if you have the dealer do it, no inspection. it's only change every 15k and expensive.
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    A clogged filter will hugely reduce your HVAC efficiency. Suit yourself but its a cheap and easy thing to do yourself. If you drive mainly in the city it should last 20-30K. More if you don't use the blower much.
  7. Okinawa
    Okinawa Senior Member
    1,333
    320
    I think it depends on the location. I live in a suburb of Chicago. At 10,000 miles mine is dirty and needs to be changed. Very dirty air here.
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    Not to mention, leaves and other debris from trees. If you park under or around vegetation.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yes, you should change it. I have never changed mine and don't plan to. My older cars didn't have one. My 2006 Honda Civic is on 173k miles in Bay Area, CA. I've never changed the filter. AC and heat works fine. My PiP is at 73k currently. Not paying $15 for a useless filter. I dust it out every once in awhile. Don't listen to me. :whistle:
  10. Mendel Leisk
    41,850
    Even Toyota says in the maintenance guide, to just inspect/clean the filter. With a proviso to replace IF it's knackered. This is excerpt from 2010 Prius guide, US versions:
  11. bisco
    52,335
    10k? huh, i thought it was 15.
  12. Okinawa
    1,333
    320
    I live in the Chicago area. Mine is dirty at 10,000 miles. I'm sure in other locations you could go much more than that. The air here is very dirty.
  13. bisco
    52,335
    it's definitely worth a check, until you get a feel for it.
  14. Mendel Leisk
    41,850
    It varies depending on solar roof option or not I think.
  15. bisco
    52,335
    hmm, isn't that interesting.(n)
  16. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Sad but true. I took mine ina few weeks ago after I bought it. I let them do the brake fluid flush and refill, alignment, cabin and air filter changes, injector cleaning, throttle body cleaning, etc. and everything else that they said needed attention. But yes, I actually went through the car to make sure they actually did all that. I guess I'm a bit cynical but don't trust the dealerships much. Everything was fine and they did what they charged for. But from now on I'll be doing most everything myself. Like you say, they'll do anything to add to the bill and make more money; even when it's not needed. NOT a fan of the dealerships at all.
  17. Air_Boss
    Air_Boss Senior Member
    4,219
    1,188
    New Yawk
    Solar roof probably drives more A/C blower hours and volume.
  18. Mendel Leisk
    41,850
    It's a bit weird. Since the US schedule goes event-by-event, I made a spreadsheet some time back, just entered everything. Solar filter has more frequent cleaning, less frequent change. Non-solar has less frequent cleaning, more frequent change.
  19. jacktechie
    jacktechie Junior Member
    33
    South SF Bay Area
    2014 Prius v wagon
    Dependent on where you drive. My daughter complained of a smell in her 2012 Kia Soul. The air cabin filter had a brownish coloration to it and it did smell bad. This was at 23 months and about 12000 miles with occasional trips from Bay Area to Central Valley. I have changed the filter once in a 2000 Ody and it's been everywhere.
  20. bisco
    52,335
    is the solar filter different? i don't understand why it would get so many cleanings, and no change until 4 years or 40,000.
