  1. SubCode
    SubCode Senior Member
    739
    1,341
    yo your garage looks like a kitchen..you could probably eat off the floor...Noice!
  2. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Thanks! Come a long way lol... Need to pull everything out and clean and wax the floors again... Dosent look this good now as i have a 3 and 7 year old! :eek:
  3. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    No biggie, added a dimming mirror and boy did I miss homelink!!!
    For anyone interested, don't be afraid to install this, it is the easiest thing to do!
    apinson34, TopRamen, ncases and 2 others like this.
  4. Serval
    Serval Junior Member
    Bay Area, CA
    I've had the car almost a week now. Today was nothing exciting but:
    1. Installed LEDs in vanity lights, parking lights, whatever light is above the parking light (?), the front ceiling lights. Didn't realize these same T10 5 led bulbs wouldn't fit in the license plate lights and that the door foot lights are hard to get into (do you really need to remove the door skin/cover?)
    2. El Grande horns
    3. Mud guards (Amazon warehouse had them for $56)
    4. H9 bulbs modified to replace H11 high beam bulbs.
    5. Not a mod, but replaced the engine and cabin filters
    6. Pulled a couple door dings with the Ding King and took out some scratches left by the prior owner.
  5. Frozzie
    Frozzie Junior Member
    Sydney
    Another small change, 2 Michelin XM2 in front. still the original BF250 Eco at the back but probably just for another couple of months.
    #8185 Frozzie, Jul 3, 2015
    Ramtart likes this.
  6. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    The door courtesy lights come off by pushing a tab with a pry tool. Almost like the tab to remove the vanity light. My courtesy light has some plastic shield covering the bulb. It took me a while to figure out that you slide it forward to remove it from the diffuser. Kinda hard to explain but you'll figure it out once you see it.
  7. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
  8. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Now you need the 2012 tail lights, that will confuse the dealer service writers. :D
  9. Serval
    Bay Area, CA
    Thanks for the heads up. Found a guide with pics and directions here: Prius door lights
  10. Starz
    Starz Junior Member
    37
    75
    NC
    Installed a Bestek power inverter.
    Sntfr my L801 uing Tapak
  11. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Nice. Which one did you get 300 or 200w? Do you have to worry about unplugging
    12 v every day to prevent draining car 12v battery?
  12. Starz
    Starz Junior Member
    37
    75
    NC
    [​IMG][​IMG]
    I also installed the front dashcam, gps antenna, a ubiquiti nanostation wifi unit and mini router (a little overkill but good when I need to connect to long distance hotspot) and my android headunit is configured the way I want it
    Se fommy LG80 using Tatlk
    I got the 300w. Dont have to worry at all about unplugging it. Has its own power switch and turns off with the car, only uses the power it needs. The only con is that there is a tiny fan always running on the inverter. Not an issue in the center console though.
    Setfro my LG usig Tapalk
  13. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
    Happy 4th. Prius doing some road tripping to Carmel CA.
  14. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Welcome to Cali Bruddah!
    Sean Callahan likes this.
  15. ncases
    ncases Senior Member
    609
    672
    Chicago
    That's a big step for having it just a week. Congratulation!
    Serval likes this.
  16. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    hood struts
    Starz likes this.
  17. Starz
    Starz Junior Member
    37
    75
    NC
    ...cause you like turtles!
    ent frm -D801 usingalk
  18. SlowTurd
    1,156
    333
    nj
    no because i hate prop rods
    ncases and Burna J like this.
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    He actually has the G tail lights
    ent frmy VS9ing atalk
    saulbassfan likes this.
  20. Rhinoruns
    Rhinoruns Member
    61
    Madison, WI
    From the pic, it looks like you installed the GPS antenna on the window above the rear view mirror? Is that true? Can it sit inside the dash and still get signal?
    Snt frm Nexus 7using Tapalk
