How many miles before need to replace tires on Prius v?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Prius_for_me, Jul 3, 2015.
  1. Prius_for_me
    Prius_for_me Junior Member
    La Canada Flintridge
    2013 Prius v wagon
    I went in for 40,000 mile service today and they told me I should replace my tires next time. I commute on mostly surface streets. I thought the rule of thumb was 50,000 miles?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    45K miles is very good for original equipment tires.
  3. bisco
    52,289
    you really have to go by tread depth, everyone gets different life span. if you put a penny in the tread, you shouldn't be able to see the top of lincolns head.
    kithmo likes this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    It really depends on many factors, Tire Pressure, average speed, cornering, temperature. The most controllable is tire pressure, keep them up, I keep mine at 55lbs and put more air in when the TP sensor goes off, at about 40. Don't listen to tire clerks, or Toyota clerks. For some strange reason they all push the same line. They are told to. They sell tires. Use your own judgement, that always works best.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Rule of thumb is replace tires based on tread depth and wear.
    You can use a penny, a quarter or buy a tread depth indicator tool.- You can look with your eyes.
    If you got 40,000 miles or more on OEM tires, they are probably due for replacement.
    I only have 20,000 on mine, and I doubt I'll make it to 30,000.
    kithmo likes this.
  6. rjparker
    10,413
    6,521
    My 2012 factory Bridgestones went 105,000 miles with factory door jam pressures. They were rotated at 5k intervals for the first 40k and then 10k intervals after.
    #6 rjparker, Jul 4, 2015
  7. Wix
    Wix Junior Member
    Cullman, AL
    I was able to get almost 75K out my factory OEM. I did keep them rotated every 5K miles though.
    S
  8. Mendel Leisk
    41,826
    What are your tires: manufacturer and specific model?
    Get a tread depth gauge and check them for yourself? They're about 4~5 dollars, at an automotive supply store.
    When to replace your tires depends on a lot of things; how low you want to let your tread depth go, mainly. Legally you can drive 'em 'till they're down to 2/32" remaining tread depth. Personally, if they were down to 5/32" I'd be at least window shopping.
    Tire age is a factor too. For example, we purchased in Nov 2010, but our vehicle was manufactured Aug 2009, and it's tires were manufactured in the 5th week of 2009. So right now they're well over 6 years old. Our car is low mileage, garage stored, out of the sun for the most, so I can stretch it some. But I can see micro-cracking start to happen, am monitoring it. Tires do age, the rubber harden, start to crack. 6~8 years is considered the lifespan. Google how to read your tire's age.
    Ours are Michelin Pilot HX MXM4 215/45R17 fyi.
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    OP: Tyre wear depends a lot on how you drive, how well you maintain the tyres through pressure and alignment, and road conditions in your area. It is a YMMV, similar in many ways to fuel economy.
    Replace your tyres when the sidewalls are markedly cracked or less than 2 mm of tread remains. Modern tyres have wear markers in the deep grooves: when the marker is flush with the surface of the tyre it is time (or past time) to change. If you want better traction in snow or rain then consider replacing earlier than the above allows.
    #9 SageBrush, Jul 4, 2015
    xpcman likes this.
  10. bisco
    52,289
    what made you switch to 10k?
  11. rjparker
    10,413
    6,521
    Because the free Toyota Care rotations ended.
    Willy Toast and bisco like this.
  12. bisco
    52,289
    and still went 105k, amazing.
  13. srgilmore
    srgilmore Junior Member
    Stanwood, WA
    I have 83,500 miles on my OEM tires and I should get 90k or 95k without them wearing too thin on tread. I keep them at 42 psi, front and rear.
  14. mikefocke
    4,038
    1,832
    Sanford, NC
    In addition to the factors others have cited, it also depends on what tires your car came with.
    And how you want to handle the trade-off between costs and safety.
    On a 2/32 tire, in stopping tests in the wet from 70MPH the new tire would have stopped the car where the worn tire would only have slowed the car to 55MPH!!!! 4/32 would only have slowed the car to 45!!!!
    Ask them for exact measurements across the tread depth taken in three places.
  15. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I got 55k on Yokohama Blu earths, and they got better mileage than the Michelin energy saver A/S I replaced them with.
  16. Willy Toast
    Willy Toast Member
    51
    25
    Brossard, Quebec
    My Michelin energy savers 205 60R16 have lots of tread left. The car is at 105,000 KM and the tires were never used in the winter, I use 215 50R17 wheels for winter (but not recommended for pothole season in Montreal). However the sidewall compound was cracking after only a few years and now at eleven years I see that I am keeping the tires too long.
    Just need to figure out a good cheap tire for five years of relatively low mileage.
