30k service needs and cost?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brad K, Jul 1, 2015.
  1. Brad K
    Brad K Member
    173
    53
    the worst part about the dealership is the dam wait
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Not to worry -- you are a guy -- I think.
    As for the damned wait, the dealership cannot really justify charging $300+ for a 10 minute service.
  3. Brad K
    Brad K Member
    173
    53
    7 ways to keep car-maintenance and oil change costs down - Consumer Reports
    To demonstrate, we recently priced 30,000-mile/36-month service on a staff member’s 2012 Toyota Prius Hybrid. (For many vehicles, 30,000 miles or 36 months is a common service interval. Some carmakers cover routine maintenance for a standard period, as Toyota does for the first two years or 25,000 miles, whichever comes first. But after that, the car owners pay the cost.) For the work listed in the car’s manual, a Toyota dealership quoted $249. But by the time we were done, we got the job down to just $85, a 66 percent savings. Here’s how we did it.
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    So easy a kid can do it. From the same article
    Even cheaper: take the filter out and give it few swats and a little massage on the back. Then put it back.
    #24 SageBrush, Jul 7, 2015
  5. bisco
    51,896
    that article is bogus, typical cr. your best bet is to stick around here, and see what the real experts recommend for 30k service, then shop that around. avoid the dealer and chains like the plague, try to find a reliable mechanic. if you can't by word of mouth, check the triple a website.
  6. Mendel Leisk
    41,405
    For just oil change and tire rotation, $60~80 seems reasonable compensation. $15~25 seems like slavery or "loss leader".
    That's WITHOUT the engine and cabin filter change: there's no way I'd pay someone to do that, and often replacement is not warranted, depending on your locale.
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    It is not slavery when you do the work for yourself. And to be clear, the cost is for the materials. The labor is free.
  8. Mendel Leisk
    41,405
    Understand, am rolling my own. :)
  9. bisco
    51,896
    is it legal up there too?
  10. Mendel Leisk
    41,405
    Haha. Been on the wagon for about 40 years.
    Vancouver's mayor has pretty much opened the flood gates, with "medical" stuff. do not know why, but the nudge-nudge-wink-wink of it irritates the heck out of me. I'm generally cranky tho.
    Pot calling the kettle black aside (no pun intended): there have been some sad results, especially teens with brains still developing.
    I almost hope the Feds DO crack down on them: mayor Moonbeam and crew.
    #30 Mendel Leisk, Jul 7, 2015
  11. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I have the 60k coming up real soon for my C (same service as the 30k one). I purchased the filters from Amazon ($50 shipped for engine air filter and charcoal cabin air filter) plus I plan on spending $80 at my trusted mechanic shop for an oil change and tire rotation. My local Toyota dealership charged me $260 for the 30k service, and lost my business since then. Well not true, I am taking it to them for my recall work but that's about it.
  12. Okinawa
    Okinawa Senior Member
    1,333
    320
    If I were you I would change dealers. You will need an oil change and tire rotation. Check the cabin filter and air filter yourself and replace them yourself if needed. That is all that you need.
  13. Species5618w
    Species5618w Member
    140
    Not sure what's the policy for warranty works in Canada. I am sticking with the dealership just to be safe. Will switch immediately when warranty runs out.
    I have a dashcam and it actually recorded the technicians saying they have no idea how to service this strange car. :)
  14. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
  15. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    Finally got around to taking my C in for the recall. They wanted $60 for just an oil change or $100 for oil change and tire rotation (plus "inspection"), but I politely declined since I'm planning on taking it to my trusted mechanic next week. $260 would be for oil change, tire rotation, and cabin/engine filter changes. I paid $50 on Amazon for both filters and did those myself.
    I changed the engine and cabin air filter for the first time myself (last one was done at the dealership). I discovered they forgot to hook up the plastic spring arm after they did it last, and the plastic clip pieces were a bit deformed, but what can you expect from the stealership.
    The engine filter is a super easy. The glove compartment is tight but will come out for the cabin filter, and the rest is easy.
    Brad K likes this.
  16. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    Interesting, I went to the dealer for what turned out to be my last warantee covered oil change at about 31,000 miles. I had just changed the cabin air filter myself two weeks prior to that. While I was waiting the service writer came out and informed me that the technician said I need a new cabin air filter. When I told him I had just replaced it, he apologized and walked back to the repair area to let the technician know.
    When he brought the keys at the end, he apologized for the technician's error saying that he must have just looked at the edge and not actually pulled out the filter to look at it. I just took the keys are drove off, but later noticed that the spring arm had not been reconnected to the glove box door. Figured it was pay back for the tech getting caught in his little scam attempt, but now it seems to be a widespread laziness issue.
    PriusC_Commuter likes this.
  17. mark schofield
    mark schofield Junior Member
    *My dealer - Lorenson Toyota, westbtook ct - always has monthly service specials. "The Works, $24.95 for oil change, tire rotation, top off all fluids, and multi point vehicle inspection", which includes breaks. The cabin air and engine air filters are about $20 each. I go that route.
  18. lmnopaul
    lmnopaul New Member
    Orange County
    Do you mind if I ask what you actually got done with your 25,000 mile service? I ran out of the warranty of 2 years before hitting the mileage due to an extended hospital stay and will be needing that service within the next 250 miles. I'm curious what the dealer performs for that interval before the big 30,000 mile service.
  19. bisco
    51,896
    at 25k, they rotate the tyres, inspect a few things and send you on your way, all the poorer.
    at 30 k, you need oil and filter, tyre rotation, inspect a few things, inspect, clean or replace cabin and air filter. no biggie.
  20. Mendel Leisk
    41,405
    Don't let them automatically slam in new air filters, have them inspect first. Maybe show to you if possible. Depends a lot on locale when they need replacement.
    Better yet, just check the filters yourself, keep them out of it: they're dead simple.
