Auxiliary Battery advice
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mark746, Jul 8, 2015.
  1. Mark746
    Mark746 New Member
    Sunnyside, NY
    Hello all!
    New owner of a used 2007 Prius. As I've never owned a hybrid, I've been reading everything I can and heading off paranoia at the pass. Recently, after a week or so of slow starts with the red exclamation showing briefly at boot, my car died completely when someone left a door slightly ajar. I got it jumped and let the car sit in ready mode for an hour and a half. The minute it happened, I ordered a yellow top to install figuring my aux battery was on the decline. But, since the jump (3 days) every time I enter diagnostic to test the battery it's around 12 volts. The car starts immediately. Did I jump the gun? Should I return the yellow top? Or was the fact it was diminished in the first place a sign it should be replaced? Help.
    Thank you.
    Mark
  2. Barnstormer!
    Barnstormer! Junior Member
    Colorado and points abroad
    12v is too low, you'd be well served to replace the battery. It was the first thing I did when I got my 2006 (similar glitchy moments at startup) and it fixed it 100% for me. From reading around here, it's pretty common. 12.4-12.8 is what you'd like.
    FWIW, the 12v battery doesn't actually spin the engine for start, so a weak battery doesn't show itself in the same way it would in a "normal" gas engine car.
    #2 Barnstormer!, Jul 8, 2015
  3. bisco
    51,845
    new battery should read 13+ with a full charge. make sure you check/charge the yellow top before installing.
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Unlike non-hybrid cars, it takes 8 hours for the 12v battery to charge while the car is parked. Or get a battery charger.
