Bluetooth connects briefly and works on start up.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by drsjr1969, Jul 10, 2015.
  1. drsjr1969
    drsjr1969 Junior Member
    la quinta, Ca
    After about a min once bluetooth connects it fails. In setup under bluetooth it says it's off and pushing it does nothing. My phone shows bluetooth on and still paired. If I was talking to someone call does not get dropped but I have to pick up my phone and turn off bluetooth so I can hear them on phone speaker.
    Tested my phone on a nissan and it worked Fine with Bluetooth.
    Confused?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    try un-pairing you phone from the car then re-pair it. Un-pair from the Prius dashboard not the phone. delete phone on the prius dashboard then re-discover your phone.
  3. drsjr1969
    la quinta, Ca
    Yes thank you I have tried that multiple time with no luck. It's just so frustrating because it successfully connects everytime I start the car and then a few minutes later nothing and says bluetooth off and the only way to get back on is to turn car off and then restart.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    bummer! Oh well, that was my two cents worth, sorry it didn't work.
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I had to do a full restore on an iPhone 4S once because it just wouldnt connect to my car anymore. It had worked fine since I got the car, worked fine that morning, then all of a sudden, that afternoon, it just wouldnt connect anymore. If I recall, the phone would say I was connected but the car said I wasnt (or it could've been the other way around). In any case, I blew the phone away, restored it with factory firmware (and I didnt restore my data.. just started fresh) and everything was back to normal.
    Not saying this is the answer, but just throwing it out there.
    More recently, I had a bluetooth issue where it would just randomly drop my bluetooth connection. It happened after I removed one of the two bluetooth pairings I have in the headunit. In that case, I did what PK suggested, removed the pairing and just repaired and things were back to normal.
    Also, if you havent already tried, a reboot of your phone may also be worth a shot.
    You may also want to let everyone know what phone you have.
    priuskitty likes this.
  6. drsjr1969
    la quinta, Ca
    Well after trying all previous suggestions except the erase everything and start from factory new I had no luck getting it to work.
    I started deleting apps that were on my phone that I did not use anymore or did not know how they got there in the first place. I was doing a couple at a time then turning my phone off then back on and checking the bluetooth.
    That was taking too long and I had about 15 more to get rid off so I did the last 15 at once and now my bluetooth works again. So my guess is one of the 15 programs I uninstalled or turned off was messing with my bluetooth.
