What LV Battery (12V) to get for good price in Canada?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DannyM, Jul 13, 2015.
  1. DannyM
    DannyM Junior Member
    As usual, I see great battery options, including OEM and some Yellow Top thing, in the USA for about $150-$200. I'm getting quoted over $350 for both those options in Canada - far more than what the exchange rate would make fair.
    Anyone got any advice how to get a fair deal in Canada? Thanks!
  2. Mendel Leisk
    41,939
    I got a number, for the stock battery only, not installed; forget exactly, but it was around $205~215. This was a greater Vancouver dealership.
    Still expensive, comparing to regular, under-the-hood lead-acid batteries, but a lot less than your quote. Phone around?
    DannyM likes this.
  3. Roland1555
    Roland1555 Senior Member
    282
    69
    Vancouver BC
    A lot more than when I bought from them, but saskbattery is selling the Optima Yellow Top for the prius for 229. with free shipping. When I purchased they sent me one that was only 2-3 weeks 'old'; which was way better than the dusty old stuff on the shelf at CTC made by Exide.
    Roland
    DannyM likes this.
  4. DannyM
    Thanks both repliers. I found out the two quotes I had were for the Yellow Top and for the Napa high-end battery that this Napa-based shop will push to anyone who doesn't ask questions. One phone call to Heffner Toyota in Kitchener and my shop was willing to match their price of $212 +tax for the OEM battery. Probably not the best I could do, but saved a bit of money by doing a bit of research, and getting it done at the same time as other maintenance for convenience. Thanks!
  5. Mendel Leisk
    41,939
    Roland, if you don't mind:
    How was your experience with saskbattery? Was the battery tiptop when it arrived, and fit ok?
    I'm still on original battery but weighing the options. What with local dealerships asking $273 for the Yuasa, I'm considering the Optima Yellowtop now.
  6. Mendel Leisk
    41,939
    Well, I snapped: ordered the Optima Yellow Top battery through SaskBattery:
    Optima Yellow Top:
    8171-767 DS46B24R
    Talking to one of their rep's, I was hooked when he said their current stock was received two weeks ago. Hope it works out, will post an update when it arrives.
    Optima battery's info:
    DS46B24R YELLOWTOP® Prius® Auxiliary Battery 8171-767 | OPTIMABATTERIES
    SaskBattery's info:
    OPTIMA 8171-767 YELLOW TOP POST GR#51JIS $229.99 FREE SHIPPING SASKBATTERY.COM
    The OEM Yuasa S46B24R GS (comes with the car) seems to have had a price jump. Two local dealerships quoted $273, at least $50 more than when I last checked, about a year back. The Optima Yellow Top OTOH, was $229.99.
    Beside being $43 cheaper, purchasing the Optima through SaskBattery had a pleasant surprise: I only need to pay 5% GST tax; provincial sales tax, 7% in my case, is not charged. With all of this, the Optima was ultimately $64 cheaper:
  7. Mendel Leisk
    41,939
    Per their claim, SaskBatteries "packed the heck out of it":
    Measurements match OEM Yuasa battery. There's a vent opening on positive side.
    Initial voltage around 12.6, gonna need some charging, which I would do in any event.
    The Solar BA5 tester, set to spiral type AGM and 450 CCA, says actual CCA is 687. It concurs: healthy but needs charging.
    Used the Snowflake/Spiral-wound setting for first time. It'll likely charge through the evening. I'll let it sit overnight, recheck in the morning. :)
    #7 Mendel Leisk, Sep 28, 2015
    giora, m.wynn, dorunron and 1 other person like this.
  8. Patrick Wong
    18,210
    6,514
    Does the CTEK charger automatically recognize AGM batteries?
  9. Mendel Leisk
    41,939
    No, you select a mode manually. From what I've seen in the CTEK manual, and reading Optima's charging instruction, the snowflake mode is the way to go. Voltage is highest. 14.7.
    The charger felt quite warm first time I checked, about 1/2 hour after hookup. Now it's been about 1.5 hours, and it's cooled down some.
    Battery feels ever so slightly above ambient temp.
    #9 Mendel Leisk, Sep 28, 2015
    Patrick Wong likes this.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I would be interested to know what the final resting voltage is after the charge and also how it measures once it is in the car.
    Patrick Wong and Mendel Leisk like this.
  11. rifis
    rifis Junior Member
    I
    Mendel:
    How did you reconcile Sask's report of current stock being received 2 weeks ago with the initial 12.6v? I see, via the link you provided, that Optima indicates fully charged Yellow top measures 13.1v.
  12. Mendel Leisk
    41,939
    Not sure. I've heard in the past batteries were sold at around 70% charged. Also, just because they received them 2 weeks back (assuming this is true), they could have sat elsewhere for some time.
    Still charging..., about 4.5 hours now. Still not that unusual. We'll see.
    There's no obvious date on the case.
  13. dorunron
    3,318
    1,105
    Houston, TX
    Mendel,
    When you recharged your OEM battery a few weeks back, how long did the charger run before it kicked off?
  14. Mendel Leisk
    41,939
    I think around 6 hours. The OEM recommend no more than 4.2 amp charging rate, whereas the optima says up to 10 amp. The charger is 3.3, a little poky for the task. Another factor.
    dorunron likes this.
  15. Mendel Leisk
    41,939
    It had rocking CCA according to my tester. Just a little shagged from coming cross the prairies. I'm thinking good thoughts.
  16. Mendel Leisk
    41,939
    4.75 hours of charging: CTEK dubbed it done. Couldn't resist to check voltage, surface charge and all: 13.45.
    Will recheck in the morning.
  17. JC91006
    JC91006 Senior Member
    16,834
    8,604
    That original Yuasa can easily go another 3 years for you......but thinking about your cold winters, I guess swapping it out now wouldn't be a bad idea.
    At least now you have a spare
  18. Mendel Leisk
    41,939
    I won't lose any sleep over residual life in the OEM, and it starts to feel like Russian Roullete after 5 years.
    South coast BC winters are pretty mild, BTW. More so lately, global warming I guess.
  19. Mendel Leisk
    41,939
    Installed the battery this morning, and had a drive to my dentist, about 15 km in total, steep hill. Checking when I got home, car shut down:
    Voltage at jump point: 13.05
    Voltage at battery: 12.95
    As measured CCA: 645
    (This with Solar BA5)
  20. Patrick Wong
    18,210
    6,514
    Sounds good, see what the voltage is tomorrow morning prior to starting the car for the first time that day.
    dorunron and Mendel Leisk like this.
