connection between sat radio and navigation???
Discussion in 'Gen 3 Prius Audio and Electronics' started by richk, Jul 16, 2015.
  1. richk
    richk Junior Member
    San Francisco
    I have a new 2015 Prius 4 and have the 3-month trial of SiriusXM radio. I need to understand what functions would go away if I let the subscription expire. If I navigate to a destination, I get audible real-time traffic updates for the selected route. Is that from the satellite? If I am driving without a destination set, there are areas of congestion shown on the navigation screen. Satellite? Anything else?
    Thanks in advance
  2. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    SiriusXM radio has nothing to do with Navigation. If it expires ( as I let mine expire ), nothing will change other than listening to Sirius. Everything else will work.
  3. richk
    richk Junior Member
    San Francisco
    Thank you. If you know, where does the live traffic stuff come from?
  4. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    That's Entune. I have a 2013 model 3 which probably isn't as advanced as yours.
  5. richk
    richk Junior Member
    San Francisco
    Thanks. I assume Entune uses a hooked up phone. Even when there is no phone hooked up, the display shows areas of congestion. Do you know where that comes from?
  6. breakfast
    breakfast Active Member
    266
    199
    The answer will depend on if your 2015 Four has a solar roof. If it does not (like mine), traffic comes from Entune via your cell phone. If it does, traffic comes from Sirius XM with a three year traffic data subscription.
  7. richk
    richk Junior Member
    San Francisco
    Great. Mine has sunroof, so that makes sense
  8. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I am no expert, but I believe traffic data is provided 2 ways; one through the Entune app by a company called INRIX and the other though HD data in the Top 100+ markets. The Entune app works when your cellphone is paired with the Prius via Bluetooth. The HD data comes through the HD radio. If Entune is not active, you lose traffic alerts when outside the HD coverage areas. If in the coverage area, there is supposed to be an HD icon in the upper left of the display. As lumpy said, I believe all you lose is SiriusXM radio service if you don't renew your subscription after the 90 days.
    FWIW, we take several cross-country trips each year and enjoy SiriusXM service, especially Phlash Phelps and his "60's On 6" morning program, so the subscription is worth it for us. Before your 90 days is up, you should get a renewal notice with discounted rates vs the standard rates on their website.
    Traffic
    Edit: I don't have the Premium nav, so I don't know about the XM-based service. I could be wrong, but I think the ones I mentioned will still apply if you elect not to continue the XM traffic subscription after it's 3 year free run.
    #8 DoubleDAZ, Jul 16, 2015
