Help 2007 prius trunk release
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by daveyboy, Jul 17, 2015.
  1. daveyboy
    daveyboy Junior Member
    62
    nj
    With the car off and me standing at rear hatch and it is raised I pushed the latch closed manually and I cant figure our how to release it back to the unlatched position. I tried the door locks to no avail.
    as an aside I was doing this to troubleshoot why my alarm is going off alot. I have a relative new yellowtop battery installed and will replace the fob battery later.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    theres a manual release ..go in through the rear door and pull up the spare tire cover..theres a slot where you can move the lever...instructions in owner manual as well
    daveyboy likes this.
  3. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    Just use the hatch opening handle on the hatch. The latch will go to the open position.
    valde3 likes this.
  4. daveyboy
    62
    nj
    thanks fellas hatch is again operational, while troubleshooting my alarm I removed the 10 amp horn fuse to buy me some time, oddly the alarm tripped and can you believe it, a horn sounded!
    Is there a second horn dedidicated to the alarm system?
    The fuse I pulled is on the block, right side 3rd one down....
