/!\ Caution The transmission P lock mechanism is abnormal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by goldfinger, Jul 17, 2015.
  1. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    OK, next problem. I've been getting the message /!\ Caution The transmission P lock mechanism is abnormal. Park your car at a flat place, and apply the parking brake completely. Are you sure? I could just jump out now.
    This message comes in waves with a beep and heart stopping red triangle. The car drives fine and the message is gone after a restart. I've had 2 episodes over the last few weeks.
    The parking pawl appears to hold the car on mild grades. I always use the parking brake out of habit, so the transmission has never been abused.
    Hooked a multimeter to my battery and have monitored for a few days. Here are the values after sitting overnight. These seem OK. I have 2 year old Optima DS46B24R.
    • Off. 12.58v
    • Push once. 12.26v
    • Foot on brake push again 13.94v
    Also, The inverter coolant pump is humming and producing a good flow in the reservoir.
    What can I check next?
    51,522
    hatch not shut tight?
  3. Patrick Wong
    18,200
    6,499
    Usually a weak 12V battery causes that symptom. However your voltage readings are pretty good and the DC/DC converter is working given your measurement of 13.9V when READY. So I think you should just live with the problem for now and see what happens.
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Check the 12V again at the front jumper terminal (to any good clean metal ground point). Try it with the headlights or parking lights on. This will test that it's not a bad connection somewhere.
  5. goldfinger
    535
    403
    Buffalo
    uart, I checked the voltage differential between the battery and cigarette lighter. With lights and radio on in accessory mode I measured 188mV. Lights off 56mV. This seems acceptable to me, but you might have something. I may have disturbed the battery connections when I pulled the plastic cover off the top. I'll clean and dress the terminals.
  6. Mendel Leisk
    40,973
    Isn't it nuts, that dash warnings typically have not the slightest connection to the actual problem?
  7. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    Like beeping and "KEY DETECTED IN CAR" suddenly popping up, whilst driving with the key safely inside car?
  8. Mendel Leisk
    40,973
    Well it's true. :ROFLMAO:
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yeah that's all good, but it doesn't check the ground connection. If you measure from the jump terminal to chassis (with the lights on) then it confirms connections on both sides of the battery!
  10. goldfinger
    535
    403
    Buffalo
    With lights and radio in accessory mode I measure 3.8 mV from the battery negative center of post to the chassis. Again I may have disturbed things in my previous measurement activities. I still plan to dress the terminals. I know I have some red grease somewhere, but I'll probably have to buy it again.
  11. Mendel Leisk
    40,973
    Just had to try that. :)
  12. Patrick Wong
    18,200
    6,499
    That sounds pretty good to me.
  13. goldfinger
    535
    403
    Buffalo
  14. Ahmed Mahmoud
    Ahmed Mahmoud Junior Member
    Fredericksburg, VA
    I had this happen recently, after taking it to the dealer and following a step by step check procedure, it was the Engine ECU that needed to be repaced, they repaced with a used one, used ones starts at $20 on ebay.
  15. Chris Holley
    Chris Holley Junior Member
    maine
    I've had this same intermittent issue for over 100,000 miles. It's a 2005 and it runs fine. We maxed out the odometer at 299,999 four years back. We're on the original HV battery. Like Goldfinger, this only happens in rainy weather which leads me to suspect it's not an ECU issue. Any suggestions?
