What is this connector?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TheFenux, Jul 14, 2015.
  1. TheFenux
    TheFenux Junior Member
    31
    Oklahoma City, OK
    I found this while doing some wiring work down by the parking brake. Can someone tell me what it is?
    It was previously taped to a wire bundle. It has blue, green and purple wires running to it. 3 pin, white connector.
    I couldn't get the picture to post from my phone. I'll post it later if no one can identify it.
    FYI, this is in a 2012 Prius Two.
    S
  2. JC91006
    JC91006 Senior Member
    16,723
    8,546
    does it seem to interfere with a function you are using? and it doesn't work?
  3. TheFenux
    31
    Oklahoma City, OK
    No, I just wanted to know what it was for.
    S
  4. zzrguy
    zzrguy Junior Member
    88
    ny
    It where the Phlux capacitor plugs in.
    :whistle:
  5. RRxing
    RRxing Senior Member
    2,537
    1,810
    NEPA
    Easier to identify with a photo...
  6. TheFenux
    31
    Oklahoma City, OK
    After much technical difficulty, here it is, hanging out over the panel.
  7. bisco
    51,488
    i'm guessing aftermarket, but not sure. not the obd connector, right?
  8. TheFenux
    31
    Oklahoma City, OK
    Not aftermarket. Not OBD2.
    SM-N910T ?
  9. bisco
    51,488
    i just checked mine, there is the same taped to the big black cable, looks like only blue and pink wires i think. no idea, something dealer can use?
  10. qdllc
    qdllc Senior Member
    1,374
    399
    Given the Two doesn't come with all features, we'd need someone with a Three or Four to chime in and see if they have it and if it's plugged into something.
    A wiring schematic would tell us anyhow if we could get one to look at.
  11. ChapmanF
    17,705
    Poof! And suddenly there was techinfo.toyota.com ....
    Do check out the wiring diagram manual. It's not just a schematic, by the way, but a 100+ page book that will include sections laying out the physical routing of all the wiring in the car, with the locations of connectors, and another section toward the back with diagrams of the shape and color of every connector. Everything is crossreferenced that you would want to be, between all those sections.
    -Chap
  12. TheFenux
    31
    Oklahoma City, OK
    My access expired and I didn't get it downloaded while I could.
  13. bisco
    51,488
    i'm not chuffed enough to bother. it could be radar cruise, lane keep assist, or anything the higher package vehicles have.
  14. Dwal
    Dwal New Member
    NH
    little late to the party. what is the connector? I too have it lying around.
  15. ChapmanF
    17,705
