Tune to Satellite Station using Voice?
Discussion in 'Prius c Audio and Electronics' started by PaigeMiller, May 8, 2015.
  1. PaigeMiller
    PaigeMiller Junior Member
    Buffalo, NY
    2023 Prius
    LE AWD-e
    I would like to tune the radio to a SiriusXM station (for example, channel 19) using voice commands only. How can I do this? Everything I have tried fails. Thanks!
  2. pghjerry
    pghjerry '24 Prius Limited
    58
    Las Vegas, NV, USA
    2024 Prius
    "Tune Satellite Channel 19" works in my '15 Prius c 4
  3. PaigeMiller
    Buffalo, NY
    2023 Prius
    LE AWD-e
    Thanks, but my 2014 Prius C3 doesn't recognize that command :(
  4. MIpriusowner
    MIpriusowner Hiredgun7
    Swartz Creek - Michigan
    Have someone else try it. Mine doesn't always recognize my voice. Too Deep.
  5. ETC(SS)
    7,312
    Might be your NEW YOWK accent.
    Priuses are pre-calibrated at the factory for a Caly accent.
    Try sounding a little more like a kid, and do that annoying thing where you, like, raise the pitch of the last syllable of your sentence and use the word 'like' to replace any pauses.
    Good Luck!
  6. PaigeMiller
    Buffalo, NY
    2023 Prius
    LE AWD-e
    Okay, I can give that a try, but it seems to recognize the basic commands I give it, for example when I want to call someone in my phone book, or find a nearby Dunkin Donuts. I can't imagine it would work for those situations and not for tuning a radio station.
    I'll let you know.
  7. PaigeMiller
    Buffalo, NY
    2023 Prius
    LE AWD-e
    So guess what. Every command I tried in my normal voice worked fine, except for "Tune Satellite Channel 19". So if I wanted to tune an FM station at a frequency of 100.5, I said "Tune one zero zero five" in my normal voice, and I got the exact channel I wanted. And if I simply used the command "Satellite" by itself, it switched from FM to Satellite. But I couldn't get that command "Tune Satellite Channel 19" to be recognized. I tried a number of common-sense variations of the command like "Tune Satellite Channel zero one nine" or "Tune Satellite Channel one nine" OR "Tune zero one nine" and so on, nothing worked.
    By the way, exactly which syllable of "Tune Satellite Channel 19" is pronounced differently between a "Caly" accent and a New Yawk accent?
