Hitting 200,000 miles soon, Need Inventory of Repairs
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by saechaka, Jul 21, 2010.
  1. saechaka
    saechaka Member
    225
    I'm plannning on ordering the parts and compiled a list from Champion Toyota. I've found everything except for the coolant flow valve. Would anyone happen to know the part number? Thanks
  2. Patrick Wong
    18,200
    6,500
  3. saechaka
    saechaka Member
    225
    My wife said she got an engine check light last night. So, I went and retrieved the code and it was P1121. How timely is that? I'm waiting to drive another 2500 miles before I hit 200k just so I can save 15% on my service repair. :) I'm thinking twice now. Anyways, are independent shops just as capable in performing the service repairs mentioned earlier? I might see if I can find an private shop that will result in a substantial savings, such as Moss Alley Motors here in Seattle.
  4. Patrick Wong
    18,200
    6,500
    Unless the independent shop specializes in Toyota hybrids, I would question whether it will be successful. <Frankly, some Toyota dealerships have trouble performing some of the services based upon PC postings. 2G engine coolant replacement, in particular.>
    You could defer replacing the coolant valve until the car hits 200K miles, if that will help the affordability of the service.
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I just bought a used 2010 toyota prius with about 230,000 miles. what should I be replacing and also what should my maintenance schedule look like. thank you
  6. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    You might want to ask this question in the Gen III Maintenance and Troubleshooting section as the Prius you have is a Gen III.
  7. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Oh OK. Thanks
    A0001 ?
  8. Mochabuzz
    Mochabuzz Junior Member
    46
    SoCal
    • Bought in 2013 with 93k
    • 2013-15 (Spent $35 on repairs)
    • Replaced Spark Plugs at 120k
    • 2016 (Spent $2600 in repairs)
    • Replaced Catalytic Converter at 160k (Toyota Part)
    • replaced front brakes around 150k
    • 2017 (Spent $1450 in repairs)
    • New Water pump
      New Inverter coolant pump
    • New Thermostat
    • New something else (that was important... I forgot what it was)
    I love this car... My goal is 300k!
    Current Mileage: 176k
    #28 Mochabuzz, Oct 27, 2017
