Dash Board Yellow Warning Lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Indedu78, Jul 24, 2015.
  1. Indedu78
    Indedu78 New Member
    Colombo
    This morning when I started my Prius 3rd Gen 2011, I noticed three yellow lights being on. These were; something similar to handbrake light, ABS light and then the stability control light. All are in yellow. Checked tyre pressure and found that one tire was low and filled it. Also, brake fluid was near the low level and I topped it. The lights are still on. I switched on and off several times but the lights are still on. Please can anyone explain what the issue could be. Thanks Warning Lights.jpg
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    12 volt battery might be low
  3. Patrick Wong
    18,210
    6,511
    Get Mini VCI so that you can retrieve the diagnostic trouble codes logged by your car.
  4. Indedu78
    Indedu78 New Member
    Colombo
    Hi Patrick, i m clueless as to what mini Vci means?
  5. Patrick Wong
    18,210
    6,511
