How much will cost toyota dealer fog lights + install?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by James Sutton, Jul 26, 2015.
  1. James Sutton
    James Sutton Junior Member
    Hi everyone!Ive finally decided to make a switch from my old 98 corolla to buy a used 2010 prius III, not 3. I just want to ask if someone already added fog lights at the toyota dealer and how much it cost (part+install)...Fog lights are really useful here in fog and snowstorm...Thank!
    PriusGuy32 likes this.
  2. Mendel Leisk
    41,849
    Not sure about your year, but if it's anything like the 3rd generation (2010 and on) OEM fog lights, they're more-or-less ornamental. I switch ours on sometimes, on a poorly lit road. Then invariably switch them on/off a few times, just to make sure something's happening. There are aftermarket offerings, you'll need to research, and others will chime in with what's good.
  3. James Sutton
    So you are telling me that theses are kind of...useless?
  4. Mendel Leisk
    41,849
    Yup, at least the 3rd gen OEM fog lights. Again, there are aftermarket options.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have found mine to be very useful in heavy fog, which we have often in spring and fall.
    I bought mine here in the Prius Chat Shop and installed them myself.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The oem type reflector based foglights, which lack effective cutoffs to prevent glare, are basically useless. Glare not only blinds oncoming drivers, but also gets reflected back off fog into the driver's eyes, similar to highbeams.
    Foglights with a good cutoff like these are much better. They can have halogen, HID, or LED bulbs in them:
    Projector Fog lights (BOLT ON) finally! | PriusChat
    Or these LED foglights from the retrofit source:
    Morimoto XB LED Fog lights
    For both of these high quality foglights you will need foglight shrouds, dashboard switch, and wiring harness. None of them is included in the two linked foglights above. Cheap oem style foglights for the Prius is available from ebay for under $50 which you can buy to get the parts you need.
    Installing the foglights is a moderately involved process, which takes about 3 hours if you take your time.
  7. ursle
    ursle Gas miser
    1,049
    192
    NH
    err, to the original question
    as much as they can
    the fogs are useless,but they look good from the front;)
  8. xliderider
    8,140
    3,277
    Honolulu, HI
    If you can't install them yourself, then any stereo shop, or auto alarm shop should be able to install them easily.
  9. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    With the second gen. Prius the fogs are a way for the manufacturer to distinguish the high end model from the low. They come on when you turn the switch but are useless for actually driving by. I suspect the factory fogs for a gen. III would be the same. You can of course add real fogs yourself.
  10. Tideland Prius
    16,609
    They're fairly easy to install (installed them myself and I'm no handyman). I got the fogs from the PriusChat Shop. I've used them on the highway at night in blowing snow conditions. I'm not sure if they worked very well.
    The beam pattern is low and wide, which is what you want in a foglight but I don't think it throws the light out far enough.
    #10 Tideland Prius, Jul 26, 2015
  11. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    You ask what the dealer installed fog lights will cost. Why not call the dealer and ask?
  12. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    #12 PriusGuy32, Jul 27, 2015
  13. ncases
    ncases Senior Member
    609
    672
    Chicago
    My fogs became handy after One of my headlights doesn't turn on. I spared myself of getting a ticket for having it.
  14. ncases
    609
    672
    Chicago
    I installed mine by myself but needs rewiring with those ebay knock off kits. I would prefer buying straight from the dealer that would cost you around $250 for an OEM. The only challenge is to run the wire to the firewall. Taking out the bumper is just easy with some clips to undo.
    NickInNJ likes this.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    I respectfully disagree. Why spend $250 dollars to get oem foglights that are pretty poor performance wise?
    Makes more sense to buy a cheap eBay kit for parts + higher quality foglights like the two I linked in my previous post.
