Electric battery degradation
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Doctor B, Jan 19, 2015.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I like that idea. I really just suspect that all the computers are being rebooted and the ones responsible for HV Battery charge levels attempt to return to these parameters of original factory design. Toyota could address some of these issues , but they just shut the hell up. Thanks Toyota.
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I just simply bought a new PIP. problem solved:whistle::ROFLMAO::LOL::p:D
    lensovet, retired4999 and bisco like this.
  3. Andyprius1
    2,327
    859
    Cool CA
    I just love a HAPPY BATTERY
  4. Andyprius1
    2,327
    859
    Cool CA
    That's cheating, Priuskitty
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I always was a little cheater:sleep::whistle::rolleyes::oops::eek::D:D:D:D:D:D
  6. Andyprius1
    2,327
    859
    Cool CA
    You females are a all the same, I'll take a Tomcat any day.
  7. bisco
    51,843
    gen IV will have automatic reboot every time you power up.
  8. bisco
    51,843
    how are the deals on the '15 pip in michigan?
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    How did you determine gender from this post?:eek:
  10. CharlesH
    2,796
    1,163
    Roseville, CA
    Especially since priuskitty is a guy. We have gone through this before.:rolleyes:
    lensovet and Tracksyde like this.
  11. fuzzy1
    10,409
    More likely, that supposition was based on the composite of multiple past posts.
  12. bisco
    51,843
    so s(he) says.
    roflwaffle likes this.
  13. Andyprius1
    2,327
    859
    Cool CA
    I happen to already know the sex of Priuskitty, from years ago. It's all perfectly logical.
  14. Andyprius1
    2,327
    859
    Cool CA
    Finally!
  15. Jan Treur
    Jan Treur Active Member
    240
    168
    Heiloo, Netherlands
    This analysis was done about half a year ago based on data until then. I wonder whether there are new data available for the period up till now. If so, you can send them to me ([email protected]) and I will extend the analysis. Remember that it is all about the kWh input measured for charging the battery, in particular for situations when it is as empty as possible.
    Tracksyde and giora like this.
  16. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    My recent measurements (October 2015) yield 2.79 kWh average (of two measurements) for the same SOC span (see post #38).
    My EV ratio from Feb. 2014 (i.e. over 21 months) is:
    Hope this is of help.
  17. Jan Treur
    240
    168
    Heiloo, Netherlands
    As some of you know in the past I collected data and made estimations of the degradation of battery capacity. Now I have sold my PiP I want to finish this exercise and see whether it can be published somewhere. It would be nice to have some recent data points to see in how far the estimations made in the past predict them. Did you participate then (this would apply to giora, bisco, Charles H, potorap, and eug) and do you have some of such data points from the last half year, indicating the maximal number of kWh you can feed in the battery (when only two or three bars are left)?
    You can send them to [email protected]
    Thanks in advance,
    Jan
  18. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    Check out the latest results from the Idaho labs testing of 4 2013 Prius Plug-ins.
    Three of the cars have about 150,000 miles on them and the fourth has about 100,000. Check out the battery testing results to see that all 4 cars showed excellent battery capacity.
    2013 Toyota Prius PHEV | Advanced Vehicle Testing Activity
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    @Jan Treur
    I have mailed you my recent results.
    If you publish something, do not forget to link it here for the benefit of PChatters.
    @Jeff N
    Do you have data (personal or other) of the Volt's battery degradation in time and use?
  20. Jan Treur
    240
    168
    Heiloo, Netherlands
    Thanks, very interesting info! I will also incorporate this.
    Do you have any idea where these 4 cars were used (concerning climate)?
