2014 prius backup oem camera grid guidelines settings
Discussion in 'Gen 3 Prius Audio and Electronics' started by bear15, Sep 19, 2014.
  1. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Agreed on the sunshine "washout" of the screen...definitely not an optimum design.
    52,263
    because other vehicles don't get 50 mpg?:p
  3. Boston Jim
    Boston Jim Active Member
    202
    148
    Have you tried the trick of turning the contrast way down and the brightness up? It helps a lot, not perfect but supriseingly well.
  4. SaZoMi
    SaZoMi Junior Member
    Oostende
    Has anyone to succeed return lines with Rolexgmt installation document or at least enter guidelines settings?
  5. Jas5
    Jas5 Junior Member
    CA
    2014 Prius Plug-in
    I tried this and could not get it to work
    Anyone else had luck seeing the guide lines on backup camera for PIP 2014 ?
    With this guide or otherwise
  6. bisco
    52,263
    nope, not in n/a
