  1. Xterra72
    Xterra72 Senior Member
    1,433
    1,680
    Just noticed @Dawit sold his car. Clean. Not much to do to it. All upgraded. Lucky buyer. Who is the new owner?
    #8561 Xterra72, Aug 1, 2015
  2. Xterra72
    1,433
    1,680
    Blacked out rooftop or steering wheel upgrade. ...... hmmmmmm.(n)
    Shark fin antenna and roof spoiler will have to be removed and repainted.... (alot of work)...:unsure:
    or steering wheel upgrade.... having to sell the steering wheel and a realignment of the wheel. Decisions decisions....o_O
    Maybe keep as is and no work involved.:D
  3. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    With all that on your mind keeping it as is dont work bro! Trust me!
    Xterra72 likes this.
  4. Xterra72
    1,433
    1,680
    Really just a thought. . But if I was to do the next upgrade it would be these two.. if it wasn't for the shark fin and the roof spoiler, I probably would have already blacked out my roof.
    Accordlayingkit likes this.
  5. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    isn't your persona has the special red stitch and dark finished steering wheel? why change it! I do not want to touch or deal with air bag removal, just my gut feeling what if it doesn't deploy in case of something happen!
  6. Xterra72
    1,433
    1,680
    No red stitching but definitely a dark finish. Not sure if it's leather or pleather (fake leather )
  7. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Wasn't really too hot on the GT86 wheels until now. Helped my cousin paint his brake calipers today and told me he'll give me his stock wheels when he buys his new ones. Starting to consider it. I was gonna paint my calipers too but ran out of time.
    Ramtart, ncases, Johnsk93 and 4 others like this.
  8. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    G's HID adjustment.
    These JDM headlights are designed to have a spread that sweeps up to the left, rather than to the right as they should be on US roads.
    I fiddled with it a bit before but I wasn't having any luck. Turns out I was fiddling with the wrong adjustment. I overlooked the lower adjustment screw.
    You need an extra long phillips head to get in there.
    Ramtart, ncases, HelloHybrid and 2 others like this.
  9. nedear88
    246
    142
    the G's headlight are set for RHD drive cars, that's why the left headlight aim higher since cars in Japan drive on the opposite lane vs U.S freeway, I hope yours did not have glare to the oncoming traffic, the screw that has a gray housing is the auto leveling headlight adjustment.
    Dylan Doxey likes this.
  10. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    ooo! soon-to-be WGM 86stock wheel twins! dont forget to get spacers to counter the caliper clearance issue and centric rings!:D
    HelloHybrid and sfv41901 like this.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes, unlike the US spec halogen & LED headlights with 1 adjustment, the JDM G headlights have 4 adjustments. 2 for the low beam & 2 for the high beam.
    Glad u got it figured out. It beam pattern still needs a lil tweaking.
    VS980 4G ?
  12. HelloHybrid
    482
    1,483
    LOL I feel like we'll have green and red WGM twins if I continue down this path.
    sfv41901 likes this.
  13. Dylan Doxey
    1,389
    3,459
    92
    It's my understanding that the beam pattern will never be just right without changing the cutoff plates. Do you suppose that's something that could be fabricated?
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I meant the alignment.
    It's ur alignment I'm referring to. Both headlights should be aimed at the same height & where the merge into 1 when at a certain distance like mine in this pic.
    As for the cutoff......there isn't much u can do as these projectors have the cutoff shield molded into the front portion of the projector it's self. U can sand it down & reshape it with a LHD step. Other option is to retrofit another projector in there.
    VS980 4G ?
  15. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    I hope your front end is sitting high in this picture. That's high!
  16. Dylan Doxey
    1,389
    3,459
    92
    I know you and I have discussed this before. I would like to understand the anatomy of this headlight better.
    This is the only illustrated parts break-down that I've seen:
    The molded projector molding that includes the cutoff plate must be integrated with the inner housing assembly itself.
    ncases and sfv41901 like this.
  17. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    The lucky buyer was someone local here in Phoenix :)
    Xterra72 and Dylan Doxey like this.
  18. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yeah, it's on an upward slope to get a good shot
    VS980 4G ?
  19. TopRamen
    TopRamen Senior Member
    307
    578
    Fremont, Ca.
    Installed the most expensive license plate frame on the Prii this morning (some perks when you donate to the California Highway Patrol Foundation). image.jpg
    Tracksyde, ncases, Johnsk93 and 4 others like this.
  20. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Had rear fenders rolled yesterday in preparation for coilovers.
