Transmission Oil Leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vmich, Aug 4, 2015.
  1. Vmich
    Vmich New Member
    Fenton, Michigan
    My 2005 Prius has a slow fluid leak from the driver’s side front transmission cover. My dealer says their books do not provide a repair for this and recommend replacement of the hybrid transmission (~$2800). Does anyone have any information on this repair or suggestions for less expensive alternatives?
  2. JC91006
    JC91006 Senior Member
    16,496
    8,406
    this is very unusual, has the car been in an accident? How long have you had the car? How many miles on the car?
  3. Vmich
    Vmich New Member
    Fenton, Michigan
    I bought the car new and put on all of the 186,000 miles. No accidents and no problems. Do you think the cover can be removed and replaced with a new gasket?
  4. bisco
    49,741
    welcome! how big a puddle is under it every morning? do you check the level? $2800. is cheap for a new tranny, but you can get a salvage for almost nothing and pay a good mech to install it. no idea if that gasket can be replaced. all the best!(y)
  5. JC91006
    16,496
    8,406
    with 180,000 miles, I would not replace just the gasket. The transaxle is worn and the work involved is the same as putting in another one. I would source a good used low mileage transaxle and replace.
    m.wynn likes this.
  6. ETC(SS)
    6,585
    With 180,000 miles, I would not replace just the gasket either.
    First?
    I would determine the leak rate.
    If you're using 1 quart every 180,000 miles, I think I would replace the fluid....USING OEM FLUID.... and not some fancy-scmancy additive.
    If your leak rate is extremely low, I think I'd try to leg this out until something more expensive breaks.
    Good Luck!
  7. Vmich
    Vmich New Member
    Fenton, Michigan
    Leak rate seems to be about a few drops in couple of hours. I can go several weeks between adding.
  8. JC91006
    16,496
    8,406
    maybe you can re-torque those bolts and see if that helps. I fixed a valve cover gasket leak on my 3.4 liter 4runner engine, just by tightening all the bolts.
  9. Vmich
    Vmich New Member
    Fenton, Michigan
    Good point. I had the dealer look at it but I didn't ask if they tried that.
  10. bisco
    49,741
    if that doesn't work, loosen up as many as possible and inject some gasket sealant, unless that would warp the cover.
