Buzzing and vibration from AC compressor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by arescec, Aug 12, 2015.
  1. arescec
    arescec Active Member
    238
    105
    Croatia
    I've bought a used Prius 2010 V this winter and didn't use AC until summer. Now that it's summer I have noticed that AC compressor is pretty loud (esp. when turned on for a few seconds) - loud enough that it can be heard even when engine is running but faintly. Some vibration from compressor also can be felt when not moving (parked) and touching brake pedal. Noise is about as loud as mobilephone left on vibrate on a wooden desk, but higher pitch and a bit muffled, or as loud as a climate control fan on max setting.
    Would that be normal?
    #1 arescec, Aug 12, 2015
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    With the windows closed I can hardly hear mine. Does it blow cold air?
  3. bisco
    52,162
    i think the noise and buzzing gets worse until they fail. nothing you can do unless you want to replace it prophylactically.
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Without actually hearing it, it's hard to tell. I can hear mine too on 1 and 2 bars. I can feel mine vibrating too through the brake pedal. It has been like this from day one.
    arescec likes this.
  5. bisco
    52,162
    i can hear mine, and it's fairly loud outside the car. but not with the engine running.
  6. arescec
    238
    105
    Croatia
    Guess that it might be normal then. I didn't notice it at first until I opened the door while car was stopped.
  7. Den49
    Den49 Member
    498
    272
    Maryland
    Mine buzzes, but I don't feel any vibration. Since it is a variable speed compressor, the buzzing noise is louder at higher compressor speeds. I think the buzzing is normal.
  8. Mendel Leisk
    41,730
    Doesn't seem normal. I notice little or no difference in sound or vibration when I use the AC.
  9. Den49
    Den49 Member
    498
    272
    Maryland
    You will notice the variation in compressor speed, if you have normal hearing, when the weather is hot and it runs at high speed initially then tapers off to lower speed as the interior reaches the set temperature. This is a high speed electric compressor that gets louder with age like they do in other applications but is not a cause for concern. Just run it until it breaks.
    orenji likes this.
  10. orenji
    orenji Senior Member
    5,887
    3,488
    When I first bought my car, I too thought it sounded weird and asked the dealer about it. I was told that is was normal and that there was nothing wrong with it. I use the A/C almost 365 days a year, and It is working fine.
    Den49 likes this.
