Cd stuck hdd unit
Discussion in 'Gen 3 Prius Audio and Electronics' started by Zuko89, Aug 14, 2015.
  1. Zuko89
    Zuko89 Junior Member
    34
    Holland
    I cant get my cd out of the unit, it open and closed the radio but i think its stuck, how do i remove it?
    52,391
    try disconnecting the 12v negative for a minute to reset everything.
  3. Zuko89
    34
    Holland
    I have to remove te radio for doing that?
  4. bisco
    52,391
    no, in the hatch, right rear corner is the 12 volt starter battery.
  5. Zuko89
    34
    Holland
    Okee, thank you, i Let you know.
  6. Zuko89
    34
    Holland
    It came out now without a problem
  7. drifterdon
    drifterdon Junior Member
    Greene, RI 02827
    hello, new to this forum. My jbl 4 disc player wont eject cd's either. I read somewhere that if you disconnect the ground you need a passcode to reset the player. Some kind theft deterrent. Is this true? I just got the car used from a dealer and do not have that info, unless its in the owners manual or something. any help would be appreciated, thanks in advance
    Don
  8. ChapmanF
    18,547
    I've had the battery disconnected beaucoup times in my Gen 3, and the JBL changer has never asked for a password or complained in any way.
    -Chap
  9. Mendel Leisk
    41,904
    No, there's no code required after battery disconnect.
    You're maybe thinking of Honda, some models have that, a royal pain, btw. Best to afix a sticker with the code in the glove box: no one would want to steal the stereo I think, and the thing is a #&*#$ brick if you lose the code.
  10. drifterdon
    Greene, RI 02827
    thank you very much, ChapmanF Am gonna try it today. I just bought the car and the cd player went bonkers on the way home. Also the screen got stuck in the open position but has since closed, cd's are still stuck. is removing the fuse the same as removing the ground?
  11. drifterdon
    Greene, RI 02827
    does anyone know if removing the fuse would have the same effect on the cd unit as disconnecting the ground from the battery?
