Is this necessary at 70K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ultragc, Aug 12, 2015.
  1. frodoz737
    frodoz737 Top Wrench
    4,722
    2,517
    33
    Funny how the 2010 through 2015 year models are essential the same car using the same fluid too. Now if they would just fess up to the WS ATF fluid exchange oversight.
  2. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    That will happen if and only if they start having to pay significant numbers of warranty claims due to unchanged WS.
  3. Mendel Leisk
    41,913
    Yeah it's good that they come around on issues like this. The other approach is to listen to your lawyers, dig in your heels, in the mindset that any revision would be an admission of past neglect. Yeah, I hope they do introduce the transaxle fluid change.
  4. frodoz737
    4,722
    2,517
    33
    I am of the opinion that most Prius driver/owners are the wait until it breaks kind anyway...but it would be nice.
  5. Okinawa
    Okinawa Senior Member
    1,333
    320
    One Toyota dealer told me it would do more harm than good to change the brake fluid. I just don't change it but I am not saying that is the right thing to do but I have not had any problems by not changing it.
  6. bisco
    52,396
    me neither, but my '04 only has 135k. not sure what will happen down the road...
  7. frodoz737
    4,722
    2,517
    33
    BS. It will harm nothing...except maybe their future repair profits.
    #27 frodoz737, Aug 16, 2015
  8. bisco
    52,396
    when i was driving german back in the 80's and 90's, it was every year with the oil. maybe it was the carpy materials they used.
  9. ultragc
    ultragc Junior Member
    us
    Thanks guys... very interesting read.
    BTW. I made a typo in my initial post. I have a 2012 model... not 2010 as stated. My apologies. I would think all the suggestions/comments still applies.
  10. bisco
    52,396
    certainly, even less is needed except toyota's recommendations.
  11. fangstar
    fangstar Junior Member
    CA
    Thanks. Got back from the dealer today and they gave similar recommendation.
    wiper insert
    cabin filter
    fuel injection service
    air mass sensor service ???
    brake flush
    i'll do the wiper, cabin filter, fuel injection serivce myself . i'm 2011 60K. Brake flush on the fence
  12. CR94
    CR94 Senior Member
    2,752
    1,207
    Northwestern S.C.
    You used fish oil in them yearly?
    bisco and ftl like this.
  13. qdllc
    qdllc Senior Member
    1,377
    400
    Yeah. Those darn Germans and their fish-based products. :ROFLMAO:
  14. bisco
    52,396
    there was something fishy, that's for sure.
  15. JTM2955
    JTM2955 Active Member
    475
    185
    Brake fluid is hygroscopic. That means it can absorb water from the air (humidity). That can lead to corrosion in the brake system. You don't want that. But, at 70k miles and what five years old? I would do whatever Toyota says, not the dealer.
    A tune up with fresh spark plugs? Not until 100k miles. Dirty air filter, buy one and do it yourself.
    Throttle body cleaning is straight upsell. To really do any good, the air flow sensor or meter needs to be removed and cleaned. I have done mine twice in 155k miles.
    You know, if its getting great fuel mileage, then why spend the money. Don't fix it if it ain't broke.
    LG G3 T-MOBILE phone ☎
  16. Mendel Leisk
    41,913
    Toyota is now saying something like 3 years or 48000 km for the brake fluid. In the 2014 reg Prius maintenance schedule, Canadian version that I downloaded.
  17. qdllc
    qdllc Senior Member
    1,377
    400
    On flushing the brake system, I've not worked with a Prius system, but I know people who have used a "vacuum bleeder" to "suck" out the old fluid. Supposedly, it would work with a brake system turned off. Once you power on, you'd have to apply the brakes a few time to ensure the lines are pressurized and pads seat properly, but you'd do one last top off of the reservoir and be done.
    Anyone know if this is so or do I really need to go to Toyota.
  18. frodoz737
    4,722
    2,517
    33
    Prius hydraulic brake flush is one of the few things I let the Dealership do...but this is a choice.
    For anyone that thinks the Prius has some kind of magic brake fluid, know this. It uses DOT 3. Do your own thorough Googling and if you think you know more than the rest of the world, so be it. At least Toyota finely came around. The same applies to the Toyota WS ATF.
    #38 frodoz737, Aug 20, 2015
  19. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    We had a thread a few months ago (started by me) on the third and fourth items and the consensus here was they only thing those do is clean out your wallet and that if a procedure isn't in the maintenance schedule and there's nothing wrong with the car, then don't do it.
  20. mbtans
    mbtans Junior Member
    Jacksonville, FL
    When I took my 2010 in for a brake recall last year the dealer replaced the brake fluid. Small bonus for the inconvenience of a recall.
