Ripped stiffening plate area
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sezy, Aug 18, 2015.
  1. Sezy
    Sezy Active Member
    434
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    This is what happens when you lower your Prius with a stiffening plate bar. At First I was bottoming out on the bar but saw nothing more than scrapes. Avoided speed bumps and learned how to drive a lowered car more cautiously,even have a front camera to avoid large bumps. Really wish I would have just removed this bar then and there for a slimmer one.
    I don't recall hitting anything or hearing a loud noise. Nor did I feel anything weird,break, or jolting like one would feel bottoming out. When I race I check the whole car over so this was not caused during racing.This happen sometime in daily driving. Car was not in any accidents.
    It's wedged up into the frame!!! Can not be pulled out by hand.
    Does anyone have suggestions on how and if this is fixable? Was thinking a shop can weld it on or better yet a different kind of bar. Any other braces I can get to help since this is a weak point now? Maybe drill holes and see if I can add my stock one near this? Help, this sucks
    This is my experience with this product. Yours hopefully varies.
  2. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Going to have a exhaust shop look at it tomorrow. (n) Thinking of getting a 2 point under brace. Really hoping I can re-add my stock stiffening plate behind the messed up bar.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Anyone else drive this car?
  4. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Nope just me. Must have happened in the past week. Last time I raced was months ago.
  5. alekska
    alekska Active Member
    435
    138
    Atl
    Some welding is in order! A welder will need to install 2 metal plates on the inside, where the nuts were, and then weld in new nuts for re-installing original/Mikes stiffening.
    - Alex
    #5 alekska, Aug 18, 2015
    valde3 and Sezy like this.
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    a good welder/ fabricator can fix that. it really won't be too difficult, but will take some time. that is why I haven't lowered mine. it may be possible to reinforce the oem plate on the top side so you don't lose any ground clearance. one thing, that is a pretty stout brace, it doesn't appear to be deformed from whatever hit it.
  7. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Wanted to have my stock bar and it welded in. Found out after welding the stock brace on in front of where it was originally the ebay users is aluminum so can't weld that to the frame. Said rewelding where it was ripped from might just fall out while welding since the frame part is so thin, may not take the heat well with the holes. Looking for another factory bar to try adding in addition.
    Such a bad day. While jacking the car up for this I had the trunk open becasue I had to disconnect both 12V battery leads and the orange plug on the HV battery. Freshly painted trunk his is garage and scratched my spoiler and trunk lid. Lowered the car to close the trunk. When it came time to reconnect the battery, the trunk would'nt open. Duh .Had to crawl over my subs and blindly reconnect the battery.
    Warped
    Plastic caught on fire.
    Still need to clean it up a bit then paint it.
  8. 69shovlhed
    2,170
    751
    Delaware
    imho, the mike ebay users one who shall not be named is fine if you don't lower the car. if your gonna lower it, reinforce the stock brace, or buy the overpriced billet plate if you don't have access to a mig or tig welder.
    DadofHedgehog and Sezy like this.
  9. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    #9 Sezy, Sep 3, 2015
  10. 69shovlhed
    2,170
    751
    Delaware
    I'd hit a junkyard.
    Sezy and Daves09prius like this.
  11. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Try autobeyours.com
    Steve has a number of totaled Gen II's hanging around, so he should have a good supply of the factory part. If you ask, he may even cut-out the bottom ribs in that area of the chassis to be welded in place of your ripped ones.
    Bill the Engineer
    p.s.: My best guess is that a speed bump snagged your car.
    Sezy likes this.
  12. slatey
    slatey New Member
    Seattle
    The block vs a wedge, seems that it may likely catch on something, what are the chances of the ebay users design having this happen on a stock vehicle? Anyone with a non-lowered Gen2 ever have issues, other than scrapes?
  13. 69shovlhed
    2,170
    751
    Delaware
    I got the Rude person's box beam brace, stock height, no problems. actually, now I've got taller tires, so ground clearance is even better. I would like to drop the rear about 1/2".
    #13 69shovlhed, Sep 6, 2015
    Sezy likes this.
  14. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Had a buddy flatten out a side of the bar then ran a bead to join the two and welded the sides. Took it for a spin and feels better.
    Note the Earth and Moon on the spoiler. I really need to get some Star Wars stickers on there too.lol Snapchat--1763180104543776881.jpg Snapchat--205268837778930318.jpg
    Painted to avoid rust.
    If this breaks I'm adding a third one.
  15. 69shovlhed
    2,170
    751
    Delaware
    i don't think its gonna break unless you total the car
  16. Bill the Engineer
    1,048
    2,278
    467
    That is going to depend on the quality and location of the welds, and how much cornering stress is going to be applied when the floorpan is trying to flex. Flexing cycles can propagate crack growth in those welds.
    I still think the problem started when a speed bump was taken at-speed and the car bottomed on it while still in motion. Don't do that!
    Bill the Engineer
  17. 69shovlhed
    2,170
    751
    Delaware
    if he had the subs rocking its no wonder he didn't hear it...
    DadofHedgehog likes this.
