2008 prius red triangle, check engine,vsc and low acceleration
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chiemena obinnwa, Aug 18, 2015.
  1. chiemena obinnwa
    chiemena obinnwa New Member
    usa
    hello guys, some days ago while i was driving, the check engine, red triangle and vsc lights came on and immediately my car slowed down. it would take longer to accelerate and every once in a while upon getting to a stop sign, it would take long to get to 5 from 0. could this be my hybrid battery going out? my regular scanner can't pull up any codes on a prius. any help pls!!
  2. JC91006
    JC91006 Senior Member
    16,496
    8,406
    How many miles on your car? You would need a better code reader to access the prius codes.
    A minivci from Amazon will work. It runs off a Windows laptop
  3. bisco
    49,742
    welcome! without codes, it's hard to say, but it could be your battery. not sure about the vsc though.
    it's always worth checking the 12v, when any lite comes on.
    if you can't purchase the $25. mini vci anytime soon, swing by auto zone for a free scan. or toyota for $100. for so for a real scan.
  4. chiemena obinnwa
    usa
    ok. i wont be able to purchase that anytime soon. just wanted to know from anyone if its a symptom of hybrid battery going out or the 12V battery.
  5. JC91006
    16,496
    8,406
    You can't diagnose a problem without the right tools. There's much more to a Prius than just the batteries
  6. chiemena obinnwa
    usa
    i actually have a scanner but its not able to read a prius. it reads all other cars. i never knew the mini vci was 25 bucks. i can afford that but does oreilly or autozone carry it?
  7. bisco
    49,742
    amazon, and you need windows to operate it.
  8. chiemena obinnwa
    usa
    ok, and this is able to read prius codes?
  9. bisco
    49,742
    yes, it's a gray market version of toyota tech stream.
  10. chiemena obinnwa
    usa
    from the reviews i read, it says it only works on windows xp or windows 7 32 bit. i have windows 8.
  11. chiemena obinnwa
    usa
    i just came from oreilly and their reader couldnt read the code on the prius.
  12. Patrick Wong
    18,200
    6,479
    It is time for you to buy Mini VCI and a used laptop that will run Windows 7, 32 bit OS.
