Master warning light fails to come on during startup?
Discussion in 'Gen 2 Prius Main Forum' started by 2009Prius, Mar 26, 2009.
  1. Suzazoom
    Suzazoom Junior Member
    40
    Utica MI (north of Detroit)
    the Master Light does not come on for my 2008 toyota prius but sometimes comes on for my 2006 prius.
    52,229
    thank you!(y)
  3. dolj
    dolj Senior Member
    8,496
    4,313
    Wellington, New Zealand
    If you see the red triangle briefly flash on start up, it means your 12 V battery is low. Check your 12 V battery and charge it up. If it fails to hold a charge, replace it.
  4. Suzazoom
    40
    thank you very much for letting me to to test my 12 V battery. I just got the 2006 prius 2 weeks ago and I don't remember seeing the 12 volt battery changed in the pile of service records.
