  1. SubCode
    SubCode Senior Member
    739
    1,341
    Cleaned out the garage and finally parked in there first time since I bought it April 2015.
    #8801 SubCode, Aug 22, 2015
  2. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Mod Party @SubCode garage! :p
  3. SubCode
    739
    1,341
    all I need is an air compressor, Masta Sean and tools....Burna J, has a better bachelor mod party pad...and has the other essentials , Beer and food.
    sfv41901, Accordlayingkit and orenji like this.
  4. Bagito
    Bagito Junior Member
    32
    Los angeles
  5. Bagito
    32
    Los angeles
    Here are some pictures of the windshield in the shade and in the sun.
  6. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Achtung! I installed (German) wheel-specific valve stem caps!
    To translate:
    VL = Vorne Links = Front Left tire
    VR = Vorne Rechts = Front Right tire
    HL = Hintern Links = Back Left tire
    HR = Hintern Rechts = Back Right tire
    The advantage of this mod is that I will immediately know if the dealer or Costco actually rotates the tires or not!
    Besides, these caps satisfy the inner Obsessive-Compulsive in me!
    Burna J likes this.
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    How do you verify that they changed the oil and filter element? ;) :D
    Burna J likes this.
  8. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    They just keep your valve cap and install the green one on there. LOL
  9. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    So I've reinstalled my valentis twice now and can't figure out why they won't fit flush. All the clips are holding and popped in. I've even tightened the nuts. Any ideas?
    Right side:
    Left side:
  10. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    I just had my routine maintenance on my car, what I always did was, I use a white chalk to draw a line on the inner side of my 2 front tires, put a dent on the oil filter and checked the oil after they handed me the car was really yellow clear.
    iPhone ?
    Accordlayingkit likes this.
  11. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    HelloHybrid likes this.
  12. HelloHybrid
    482
    1,483
    Yeah, I'm starting to think I have a defective unit.
    I took a break and looked at other people's pictures and the fitment of mine looks nothing like everyone else's. I just got the car back together before I lose daylight again. While playing around with the lights, I noticed the inner housing on the right side was a little loose. I tried to tighten the screws and they kept spinning. When I opened it up, I found that some of the pieces where the screws thread into were broken. I had to replace some screws with longer ones so they'd reach and fully tighten.
    It didn't seem to affect fitment though. I'm gonna write to the ebay seller and ask about getting an exchange at this point.
  13. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    I can see clearly now that my camera is on.... Blind spots are real in the Prius!
    This was a pain in the azz and I pray this cheap thing doesn't stop working lol!!!
    HelloHybrid and Accordlayingkit like this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Meet up with @saulbassfan Friday morning
    Had a nice photo opp on Friday when leaving work
    Then I got home & I found these waiting for me
    VS980 4G ?
    Burna J, slowpriusj, apt5020 and 3 others like this.
  15. orenji
    orenji Senior Member
    5,887
    3,488
    That will look sweet on your projector's! :) You have risen the bar again!
    sfv41901 and Accordlayingkit like this.
  16. slowpriusj
    167
    271
    Brunswick, MD
    Love the etch, make sure you do a walk through on the clear lens :)
    sfv41901 likes this.
  17. shaotai
    shaotai Member
    34
    39
    Seattle, WA
    I also swapped in clear lenses from TRS in my G's headlights also, but I went with the STi-R lens.
    Here is the original fresnel lens.
    Here is the new STi-R clear lens.
    While I had the headlights apart, I fixed the RHD shield to flat, then painted the front of the shield in blue.
    I haven't taken any output shots, but it's nice and flat now and no blinding the oncoming traffic. :)
    The blue shield is generally not noticeable, but in certain angles looks really good.
    Was definitely a lot of work taking them apart and modifying the shield, but it's worth it once you see the output. (Maybe I'll post a write up)
    Snow, Ramtart, RightOnTime and 3 others like this.
  18. el Crucero
    1,628
    699
    Inland Empire
    This is not a good sign! Something is going down! :cautious:
  19. JayLn
    JayLn Active Member
    248
    141
    Four Touring
  20. SubCode
    739
    1,341
    I'm having a bit of trouble finding those LED lower turn signal/running lights....where did you finf them..I've nee looking on auto style-USA. ebay, yahoo japan , and amazon....????
