How long should 12V battery last in accessory mode?
Discussion in 'Gen 2 Prius Main Forum' started by holysmokes99, Aug 24, 2015.
  1. holysmokes99
    holysmokes99 New Member
    Victoria
    Hi all,
    Just entered the hybrid world 2 weeks ago with the purchase of a 2007 Prius. Love the car, but I think there is a 12V battery issue that needs to be addressed. Twice now we have drained the battery and needed to jump it. Once I think I accidentally left it in accessory mode, and the other we were on a ferry in accessory mode. Both times the accessory mode was on for about 1 1/2 hours. That can't possibly be enough to kill the battery, can it? The battery test using the display screen diagnostic indicated good voltage when in accessory mode and when running.
    Thanks for any comments.
    Cheers,
    Marcus
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    My sincere advice: Never use ACC mode. Never use ANY electricity in a Prius unless you are in Ready.
    The 12 volt battery is very small. Draining it is easy and means jump starting your car. Reversing the cables while jump starting costs $4000 USD. None of us have $4000 to spend. So stay in Ready.
    If for some reason you feel your life is not possible without ACC, buy a little jump start box or cables that are polarity compensating.
    Amazon.com: Schumacher IP-125 Instant Power Jump Starter With 12 Amp Hour Battery: Automotive
    Amazon.com: Juice Performance BC0880 SafeGuard 16' 6 Gauge Booster Cable: Automotive
    #2 JimboPalmer, Aug 24, 2015
    WilDavis likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I will second what Jimbo said. Just leave it in "Ready Mode". Chances are the 12 volt is original which is not helping matters, As stated above, the 12 volt is very small and it does not take much to drain it.
    Best of luck to you and "Welcome to Prius Chat".
  4. Mendel Leisk
    40,923
    Jump starting and driving is not gonna restore a seriously depleted battery either. You should hook a 3~4 amp smart charger, let it run a COMPLETE cycle, and continue to monitor with a digital voltmeter.
  5. holysmokes99
    Victoria
    Thanks for the advice, Jimbo. Coming from a regular gas vehicle that seems unintuitive. So when in "Ready" mode I guess most (all?) the power is coming from the main battery? How long will the battery last? I guess the engine will start if it gets low I suppose. Have to develop new habits...
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    There are oddities in the Prius emulation of a car. <G> Besides the HV battery doing all the charging of the 12 volt battery, so you want to be in Ready, there is also the fact that no charging of the HV battery can happen in N, so you want to avoid N if at all possible. This may also not be how you learned to drive.
    Treat B like L in a normal automatic, only use it to slow your car on long steep downhills (400 meter vertical drop or more. Whistler is almost 700m)
  7. holysmokes99
    Victoria
    When jumping the car and get enough juice to get into "Ready" mode, does that mean the the 12V is now being charged by the main battery and we can relax? The issue we are having literally *right now* is that my wife is on a ferry with the car as I type this and having this problem (I am at home). The ferry crew is not allowed to jump start hybrids apparently for liability reasons, but they can trickle charge it. So when it is time for her to get off it will have been trickle charging for 2 hours. If she can get to "ready", is she out of the woods?
    Thanks!
    Marcus
  8. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Yes, she'll be fine if the car goes into Ready. As noted, in Ready the traction battery charges the 12V battery, and when the traction battery drops to its low set point the engine will come on for a short time to run it back up again.
  9. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    If she leaves the car in Ready for an hour so the 12 volt battery charges, sure. If she turns it back off before that, all bets are off.
    (The $4000 USD liability to doing it wrong may be the reason they are not allowed to jump start it)
    Out of curiosity, which Victoria? I have been assuming BC in Canada.
  10. bisco
    51,488
    do you have to use accessories on the ferry?
  11. holysmokes99
    Victoria
    Great. Thanks for all your quick advice!!!
    Yes we are in Victoria BC. This is certainly an informative forum. All of my Prius web searches have generally lead me to this site. Great community!
    Cheers,
    Marcus
  12. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I remember several great Victoria BC vacations via the Black Ball ferry from Port Angeles! Mostly I just walked on, but going the other way you would want a car. (Or maybe you use the BC ferry to Tsawwassen)
  13. Mendel Leisk
    40,923
    There's nothing intrinsically different about a Prius 12 volt battery, comparing to other cars. The only thing: it's a bit smaller. Any car in accessory mode is inexorably running down the battery, it's just a matter of how fast. And I'd wholeheartedly recommend you look into smart chargers, multimeters and just read up a bit. Jump starting and a drive does not fully restore a significantly depleted battery.
  14. bisco
    51,488
    a good jump pack may come in handy.
    JTM2955 likes this.
  15. Mendel Leisk
    40,923
    Yeah, especially for airport parking. Another good app: when someone asks you for a jumpstart.
  16. holysmokes99
    Victoria
    Yes I will certainly get a jump pack to keep in the car. Good advice.
    Thanks, Mendel
    I was surprised at how quickly the battery drained. It was less than 2 hours. In my other gas vehicle I have lasted many more than that listening to the stereo while having a long wait somewhere. Perhaps this battery is a little tired. In any case, I can live with this now knowing that the capacity is less than what I am used to.
    Cheers,
    Marcus
  17. holysmokes99
    Victoria
    Yes that is now definitely the plan!
    Cheers,
    Marcus
  18. bisco
    51,488
    bear in mind that running down the 12v one or more times can be the death knell. it is a very small battery that is designed to boot up the systems and close relays, it doesn't suffer deep discharge well.
    kenoarto likes this.
  19. ChapmanF
    17,705
    It completely depends on the capacity of the battery and how much accessory stuff you were running.
    People have already mentioned the Prius aux battery is small, but there are numbers to these things. The original batteries for Gen 2 (reading from page AP-2 in a 2004 New Car Features Manual) was a 28 amp-hour battery if the car didn't have smart-entry or nav, or a 36 amp-hour if it did have one or both of those.
    Just for comparison, batteries in the sizes conventional cars used to lug around a couple decades ago could have amp-hour ratings north of 80.
    Toyota does improve the batteries over time. Your battery part number has changed once or twice and the new one probably significantly beats the original. (Toyota's heavier upgrade for Gen 1 was about 45 when originally introduced, and new ones are labelled 51.)
    Once you know the amp-hour rating, how long you expect it to last is just a matter of division. If you're running some accessories (including the normal stuff in the car that is on in ACC mode) that total, say, 14 amps, a 28 amp-hour battery in good condition will be fully discharged in 2 hours. (Note: "fully discharged" for a lead-acid battery means about 10.5 volts; taking it any lower than that is getting into abuse.) If it's older with some capacity lost, then less than 2 hours.
    Sort of paradoxically, if there is a saving grace here, it's that the Prius battery is not designed to turn a starter motor, it doesn't need the huge CCA ratings of starting batteries for other cars, it is more like a deep cycle battery and actually handles that treatment better. (The way you get huge CCA ratings is to up surface area by making the plates really thin, delicate, and easily eroded. In comparison, a Prius battery's like a tank.)
    So it's not really that the Prius battery is especially bad at deep cycling. It's just so small that you already are deep cycling it within an hour or so with modest loads, and that's not what people are used to expecting.
    If you do deeply discharge it, one thing you can do for the best chance it comes back ok is to recharge it quite slowly and gently on a smart charger, rather than in the less-controlled setting of driving the car. When I recently drained my new one flat, it just got swapped with the old one, which is now the spare and lives indoors on a maintainer. The drained new one came indoors and went on the smart charger for a nice controlled charge before it went back in the car. It's been fine.
    -Chap
    ftl likes this.
  20. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Joined today, what a steep learning curve required, and a sense of humor to lubricate that climb.
    Really the 12 v in a Prius will last all of 15 minutes when fully charged, and kill it once, toast.
