Featured SPOTTED! *UNWRAPPED* 2016 Prius spotted this morning!
Discussion in 'Gen 4 Prius Main Forum' started by Sporin, Aug 21, 2015.
  1. bisco
    52,375
    can you clarify the question?
  2. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Three years after setting the goal, Toyota’s 2.8 liter 1GD-FTV engine reaches a thermal efficiency of 44 percent, which makes it, says Toyota, “one of the most thermally efficient engine in existence.”
    Details about that engine and its siblings: can be found in a press release dated June 19th.
  3. Starship_Enterprius
    Starship_Enterprius Active Member
    331
    163
    Ottawa, Ontario
    2018 Prius Prime
    This is why I stated the color black would be a good choice. An all black will neutralize that hideous c pillar cut out and make it look part of the rest of the car.
    JTM2955 likes this.
  4. john1701a
    john1701a Prius Guru
    12,826
    5,306
    58
    That doesn't tell the whole story though, since it excludes the plug-in hybrid data.
    usbseawolf2000, Sergiospl and JTM2955 like this.
  5. Trollbait
    12,676
    the gen2 was a better hypermiler, with a higher potential to exceed the official rating. The gen3 is just more efficient overall, but can't be push as high, percentage wise, as the gen2.
    Toyota sticks with NiMH because they have a large, financial investment in it. They secured production and nickel supplies down to the mine level to reduce their battery cost back when the gen2 became a really successful. The others switched to Li-ion, in part, because of Toyota's move. They couldn't compete with the cost difference between what they paid and Toyota paid for batteries, and there was a risk that if there was a battery shortage, they would be cut off.
    Then Toyota is a conservative company, and NiMH has a proven track record for reliability. Li-ion hybrids have been on the road for 5 years to the NiMH's 15 plus.
    Right now NiMH and Li-ion batteries are very close in cost. It is likely still cheaper for Toyota to use NiMH, but Li-ion batteries have been steadily dropping in price
    It's US gallons, but a direct conversion of the JC08 test results.
    And they just increased the efficiency of their diesels.
    Felt and JTM2955 like this.
  6. Much More Better
    Much More Better Active Member
    655
    163
    As long as Li-ion perform as well in the cold, and degrades same or less over time as Ni-MH, then I'm onboard.
  7. JTM2955
    JTM2955 Active Member
    475
    185
    That does look better, how is the vision rearward? It might be a blind spot. But, with a rear view camera it shouldn't make any difference. Blind Spot Lane Monitoring is an option on Camry that would work well in any vehicle. It works for me, no changing lanes into cars that come out of nowhere. Gen 4 would be a perfect candidate for it.
  8. john1701a
    12,826
    5,306
    58
    You forgot to include a vital bit of *NEW* information, so big it needs to be restated many times until people understand the implications...
    THE PATENTS JUST EXPIRED!
    JTM2955 likes this.
  9. Sergiospl
    3,938
    1,351
    28
    Posted to show that the cost to drive from 55 to 60mpg is probably not that significant in regular Prius.
  10. JTM2955
    475
    185
    Uh oh, there goes the hybrid neighborhood. Now everyone will have a Prius clone. Hyundai is making a Prius fighter, mules have been sighted.
  11. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Would be interesting to see another line that shows electricity consumption.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    From what little we can see here, it's not hideous. In fact, the Photoshops look worse.
  13. Sergiospl
    3,938
    1,351
    28
    Compare the side profile stance, seems a bit lower, wider, longer... I favor the top pix.[​IMG]
    JTM2955 likes this.
  14. Mendel Leisk
    41,889
    There's a lot of Prius in private hands. We'll see a lot of them scattered around parking lots. It's only when I see something like a Civic hybrid that I get excited: THOSE are rare birds.
    And yeah Prius is a very common cab. We got "hailed" once, lol. Prius v showed up in a big way too, when they first came out. A fair number of v cabs too.
    Seems now like our nearby dealership has little or no zero Prius for sale tho. And any ads you see are typically for v or c, and even that's dried up. Strange.
    JTM2955 likes this.
  15. Sergiospl
    3,938
    1,351
    28
    JTM2955 likes this.
  16. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Gen4 is almost as wide as the Prius v. The height is the same as Gen3 but with lower center of gravity. The hood is much lower. It is going to drive so differently and with higher power to weight ratio, it may blow us away. ;)
    Although the wheel base is exactly the same, the car is longer especially beyond the rear wheel. I think that'll make it more aerodynamic due to boat-tailing effect. Still a kammback hatch.
    Sergiospl likes this.
  17. rthrglf
    rthrglf Junior Member
    17
    Monterey Park CA
    Toyota has facilities at Port of Portland (Terminal 4) and Port of Long Beach (B82, B83). I imagine they ship the Prius to both ports.
    orenji likes this.
  18. Sergiospl
    3,938
    1,351
    28
    Let me introduce some of you to the floating roof c-pillar, :D
    The floating roof c-pillar is going to nice with tint, but will lose the effect in darker color.
    Also, less blindspot of the pillar with an additional window.
    orenji and JTM2955 like this.
  19. Much More Better
    655
    163
    That tail-light looks like a massive boomerang. I don't know, man. I just don't know.
  20. JTM2955
    475
    185
    Competition is good. Toyota is so conservative, they need someone like Hyundai to rattle their cage once in a while. My question is why does the Hyundai Hybrid still use a transmission?
