Front wheels noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Manhal K Alrashdan, Aug 26, 2015.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    jordan
    Last week , I changed the front wheels brake pads and had the mechanic rotating the wheels ( putting the front back and vise versa ) . ever since I had this oscillating noise and vibration when driving at 30-40 km/ hour (20-25 mph) when I speed up the noise change into a high roar without vibration >> Any help is greatly appreciated > My prius is V gen 3 model 2010 and I live in Jordan ( middle east ) .
    52,091
    welcome! how many miles/km on her?
  3. Mendel Leisk
    41,640
    A wheel weight fell off in the process? Another thing that can happen: some grit gets between the wheel and the hub when reinstalling, causes poor seating. If there was grit, and it's since shattered fallen, then fallen out, you might notice loose lug nut: check see if any seem loose?
  4. Manhal K Alrashdan
    81
    jordan
    It has about 135k miles on her.
  5. bisco
    52,091
    i would jack her up and spin the front wheels by hand. be careful, you have to make her ready and put in neutral. could be bearings, pads, velocity joints. maybe something caught between a pad and rotor?
  6. Manhal K Alrashdan
    81
    jordan
    Today I took her to the mechanic and did as you said , he jack her up and run her on D for several minutes , the noise disappeared , he suggested an uneven wear on the tread may be the cause . could it be true?
  7. bisco
    52,091
    yes, tyres can be noisy if they are not in good shape. you could try switching them again.
  8. Manhal K Alrashdan
    81
    jordan
    Thank you bisco , your comments were of great help .
    orenji and bisco like this.
  9. bisco
    52,091
    all the best!(y)
  10. CR94
    CR94 Senior Member
    2,709
    1,178
    Northwestern S.C.
    Yes, especially tires moved to the front after a long spell in the rear.
  11. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
    I am having the same issue, when my tires were rotated at 25k it started and when I had them rotated at 30k the sound switched from the front to the rear. I am hoping it is tires and I should be ready to replace them in the next 5000 miles.
  12. Manhal K Alrashdan
    81
    jordan
    My tire are in very good condition , they have about 3mm deep tread , They are Goodyear viva2 model and I,ve heard a lot of complaints about these model.. Is there anybody who use these tires ? I would like to see if it's a common complaint .
  13. Mendel Leisk
    41,640
    That's getting pretty low, if accurate: 3mm is a little under 4/32", maybe time for new tires. You might check the manufacture date of the tires too:
    Tire Tech Information - Determining the Age of a Tire
    As an example: we purchased our 2010 in November of that year, but it was built in August of 2009, and the tires were manufactured in the 5th week of 2009, ie: February, 2009. With any tire around 5~6 years old you need to keep an eye on them, check for cracking. Garage stored vs parked in the elements can make a difference too.
    #13 Mendel Leisk, Aug 27, 2015
