Which gen Prius has highest MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by Wolfy90503, Aug 26, 2015.
  1. Wolfy90503
    Wolfy90503 Junior Member
    56
    Torrance, CA
    mine consistently gets 52+ mpg so I'm voting for Gen II.
    52,390
    the '04 got 60 on the epa, but strangely, it went downhill after that. not sure if they added more weight, or reprogrammed the ecu's.
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Don't forget the record is well over 100 MPG. Held by one of the guys in Japan. I can't recall if he was in a Gen I or a Gen II
  4. Wolfy90503
    56
    Torrance, CA
    But doesn't the Japanese Gen II Prius have an EV button? That would explain the 100mpg if true.
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Gen IV suppose to have 10% better mileage than Gen III. When I first got my Prius, I was able to get 60+mpg for the first several tanks. After a year, the hype wore off. Now I just drive it normally and still get 50+ even with AC in 110f+ summer.
    Data Daedalus likes this.
  6. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    It does, but it doesn't help get better economy.
  7. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    My C outperforms my G2. But then my wife drives the G2...
    - Galaxy S5
  8. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That was the city MPG for the 2004 using the old EPA algorithm. The current algorithm has the combined MPG at 46 for the 2004.
    JeffD
    #9 jdenenberg, Aug 27, 2015
  9. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Right for Gen2 the EPA City MPG was orig 60 (51 Hwy) then 2007 they changed the EPA MPG ratings...still got my window sticker.
  10. Mendel Leisk
    41,901
    The mpg measuring methods have changed over the years too. Usually resulting in lower, more realistic values. This just happened in Canada; it was refreshing: the new values are actually achievable.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The true answer "it depends". As an example the gen 3 almost always out performs gen 2 except between 60 and 65 MPH. If you spend a majority of your day in the low 60s, it does not matter that at 70 the gen 3 would do better, and that at 45 the c would do better.
    They all do better than the v, the v only wins if the others need to make two trips, then we win big time.
  12. bisco
    52,390
    well, seeing that regularly get 70 mpg in good weather with the pip, i'm gonna have to give it my vote until the new one comes along.
  13. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    I would think the C, but I might have to vote for the Gen II after that.
    I know I was pretty disappointed to hear that they went to a 1.8L for the Gen III.
  14. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    The Next Gen? :)
  15. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    PiP of course see the recent stories about going a long long way in favorable togpgraphy
    PS- That video is more like the Prius lady yelling at the pick-up driver, but I don't wanna go there
    #16 wjtracy, Aug 27, 2015
  16. berkley
    berkley Junior Member
    88
    Minneapolis
    my 2007 appears to be getting less gas mileage than my 2005, same tires/pressure/same driver/same trip to work....what's up??
    any ideas? tech appear the same??
    please respond....thanks
    Berkley
  17. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    The Prius PIP gets the best mileage without a doubt. It isn't even close. Over the last 5000 miles,I am averaging 73 mpg and some PIP drivers do better than that! My driving includes freeways at 65 mph, mountains, and local groceries. The PIP is a joy to drive and one of the best kept secrets! (y)
  18. Mendel Leisk
    41,901
    To level the playing field, I'd think even if you never plug in, the PIP would surpass a regular Prius, due to it's battery and adjusted programming?
    breakfast likes this.
  19. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    Is that highest mpg in general over all average users or highest single mpg ever in one single instance? If it's the former it's likely to be the Gen IV if the rumors are true.
    #20 LDB, Oct 4, 2015
