What is this red switch on G1 dash?
Discussion in 'Generation 1 Prius Discussion' started by fthorn, Oct 18, 2008.
  1. fthorn
    fthorn From gas hog to greenie to gas hog
    197
    Found this on Autotrader just now.
    What is the switch for?
  2. supra90
    supra90 New Member
    30
    florida
    2001 Prius
    that have to be aftermaquet, maybe for fog lights
  3. Optimus
    Optimus Member
    274
    25
    definitely an aftermarket switch, likely sidewinder rockets. Hard to say what it is for since it could be a variety of things. If it has aftermarket fog/driving lights somewhere up front, that's probably it. Either that, or it's perhaps not even functional anymore. The switch was mounted on a blank insert.
  4. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    NAWSSSSSSSS!!!!!!!!!!
    or the EJECT BUTTON
    sorry i have nothing to contribute, im just really bored at my volunteer EMS base... no calls tonight (which i guess is good because that means nobody in this area needs to go to the hospital...)
  5. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Likely all the switch is, is a conversation piece.
  6. gippah
    gippah New Member
    121
    Austin, TX
    There were quite a few kits for the G1 Prius, clearly the first owner installed one.
    This switch could do any variety of things.
  7. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    Cruise control was actually in the ECU's software from the beginning, but it was not a gen-u-wine accessory (or, should that be "gen-u-one accessory") until a couple of years later.
    The 2001 two-volume repair manual mentions cruise in passing, but later wiring manuals, say, 2003, would show how this was accomplished.
    My 2001, one of several in my area, has cruise, but I believe it was added post-sale.
  8. ChapmanF
    18,486
    My 2001 wiring manual shows it on p. 54, with the description of how it operates (including resistances of the cruise control switch) on pp. 64-65.
    It wasn't factory installed on my 2001, but it was just a matter of plugging in the two needed switches (the stalk on the steering wheel, and a four-terminal version of the brake pedal switch). Metro Toyota sold everything needed in one inexpensive kit.
    -Chap
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    000-DESTRUCT-0
  10. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    If it's a red switch - DANGER WILL ROBINSON!!!
