Changing engine coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tochatihu, Apr 12, 2007.
  1. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The little 12v battery is an AGM (Absorbed Glass Mat) lead acid battery.
    DoctorD
  2. alanew
    alanew Junior Member
    Albuquerque NM
    you are correct my mistake.
  3. JC91006
    JC91006 Senior Member
    16,933
    8,643
    If you can change your spark plugs and battery yourself, you should have the skill set to change coolant. You just need to have the right equipment to stay safe under your car.
  4. Mendel Leisk
    42,264
    Just curious, is it necessary to pull the wipers and their motors on gen 2, to get spark plug access? 3rd gen is just nuts.
  5. JC91006
    16,933
    8,643
    gen3 just nuts
  6. Patrick Wong
    18,210
    6,517
    It is not necessary assuming you have an appropriate length extension for your 3/8" socket wrench.
  7. JTM2955
    JTM2955 Active Member
    475
    185
    No, I did loosen the big harness and moved it so to get to #4. The first three were easy. The last one just a thing in the way.
    You can do it, not too bad. Just remember to do it on a cold engine.
    LG G3 T-MOBILE phone ☎
  8. sreese01
    sreese01 Junior Member
    Patrick,
    First off, thanks for being so generous with your time in helping everyone.
    I have a '08 prius that I recently changed the engine coolant in. Car has been running perfectly following similar instructions (I did not short the CHS relay). No error codes or over heating issues. However, I used to hear the CHRS pump after turning the car on and / or off. I do not hear it run (maybe it has the proper amount of coolant not to be noisey any more?).
    Do I have reason to believe that the pump isn't running any more and will gen 2 detect if it is malfunctioning?
  9. Patrick Wong
    18,210
    6,517
    If the coolant heat recovery system pump is not running or the coolant system is clogged, then DTC P1150 normally would be logged by the engine ECU. The ECU monitors the sensor at the CHRS canister output, tracking the coolant temperature as coolant is pumped out of the CHRS canister. The sensor is looking for a big change in temperature which shows that coolant is flowing out of the canister. If it does not see this temperature change then the ECU assumes the pump is not working and logs the DTC.
    sreese01 likes this.
  10. sreese01
    If it logs such an error will it have a "check engine" light (or something to that effect) on?
  11. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Yes MIL or check engine light will light. P1150 fault only has to happen once for MIL to turn on.
  12. sreese01
    Sounds like my initial theory is not far off --- may be working "better" in comparison to the previous coolant level which may have been minimal to work without overheating. Before it had a clear high(ish) pitch tone upon start up and shut down. Now it is silent hence the concern!
    Thanks for the feedback it does help ease the mind!
  13. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    This procedure worked perfectly to fill the thermo tank (CHRS) in place of the scan tool procedure in my Bentley Repair and Maintenance Manual. While using multi-meter to monitor amps it took several 30 second runs to get up to about 4 amps. Did this while following the procedure in the manual (opening and closing the bleed screw) and continuously expelling air out of the radiator neck by squeezing the right side radiator hose and topping up coolant in the radiator. Did this until it would take no more coolant (took about 6.5-7 qts). Skipped active test mode, but drove it hwy speed for short distance. Let sit over night. Added a few ounces of coolant to radiator and overflow reservoir. Drove another short trip. Let cool, added a few more ounces of coolant and continued to monitor coolant level for a week or so - needed none. A couple hundred miles later all is well. No fancy tools needed, but the key is to ensure the pump requires about 4 amps to run, all air is expelled out of the radiator, and it will take no more coolant because all that drained was replaced. Note: I did use air pressure through the radiator to force out more coolant out while draining. Thanks to all who contributed to this thread, which was invaluable to complete this job and save a few hundred of my fiat currency reserves.
    #153 tnt01prius, Jun 27, 2016
    ETP likes this.
  14. ETP
    2,804
    1,170
    Auburdale FL
    Anyone know if the 2016 has the same issue or procedure?
  15. Mendel Leisk
    42,264
    There isn't a coolant thermos on 4th gen, or 3rd.
    ETP likes this.
  16. ETP
    2,804
    1,170
    Auburdale FL
    excellent.
  17. blaisep
    blaisep Junior Member
    48
    22
    Santa Cruz California
    I really, really wish I had found this thread two days ago... now I'm waiting for amazon to deiver the nut extractor while my car is in pieces in the driveway... :eek:
  18. blaisep
    48
    22
    Yes, nobody ever mentions those two nuts....
  19. Pinback
    Pinback Member
    62
    29
    Aboard The Prius Dark Star en route to Veil Nebula
    G'day Patrick et al,
    Do y'all recall which sizes (inner diameter = ID) of tubing or hoses are best for the coolant drains? I would really like to avoid making a mess when I drain the coolant from each loop.
    Pinback
  20. Mendel Leisk
    42,264
    The drain spigots are readily accessible: check with a caliper and/or some assorted tube diameters, in advance.
    jerrymildred likes this.
