Highlander Hybrid seen with CA HOV stickers
Discussion in 'Gen 2 Prius Main Forum' started by jbarnhart, Feb 19, 2006.
  1. elmofongo
    elmofongo Member
    252
    SF, CA
    <div class='quotetop'>QUOTE(Mr. Tuco @ Apr 27 2006, 01:34 AM) [snapback]245989[/snapback]</div>
    Jbarnhart did not report him. He said that in his post. The CHP probably busted him while he was driving.
  2. ostrich
    ostrich New Member
    43
    <div class='quotetop'>QUOTE(rustyj @ Apr 28 2006, 09:46 AM) [snapback]246623[/snapback]</div>
    I also have two sets... I applied for one set for Sparky, and then a week later he was sandwiched between two SUVs on the freeway and eventually totalled. The stickers showed up a month or two later... About 4 months after that I got Ruby, and applied for a set of stickers for her since the stickers are numbered, and the certificate has license plate and VIN info. I must have checked the stickers a dozen times to make sure I had the correct set before I put them on.
  3. Passing Gas in the OC
    [attachmentid=3218] :blink:
    No, NOW you've seen it all...
  4. cport7
    cport7 New Member
    Wine country
    I have witnessed a Honda Accord Hybrid with the yellow stickers soaring past everyone in the HOV lane...I'm affraid if so much abuse is happening.. we will loose the privelage.
  5. wstander
    wstander New Member
    982
    <div class='quotetop'>QUOTE(highroute @ Apr 27 2006, 06:48 AM) [snapback]246062[/snapback]</div>
    Heh, heh. My 2004 HCH with the 5spd manual had NO hybrid markings on it at all! In fact, I argued with the dealer until he opened the hood and proved that it was a hybrid.
    There may be other 'stealth' HCHs out there, who knows? I only know that I had one with NO hybrid, or even Civic markings.
    Walt (pushin a Prius now :rolleyes: )
    Meg&Bear likes this.
  6. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(Passing Gas in the OC @ May 3 2006, 03:55 PM) [snapback]249364[/snapback]</div>
    Ya, the stickers are the wrong place. Otherwise, perfectly legit.
  7. bigj3347
    bigj3347 New Member
    161
    Hacienda Heights, Ca
    for what it's worth, I saw a HH in Walnut, CA with a set of HOV stickers on them. It wasn't on the freeway, just on the streets. I thought originally that he also has a prius and simply applied for a replacement set for his HH. do not know for sure tho.
  8. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(jbarnhart @ Apr 19 2006, 03:58 AM) [snapback]241987[/snapback]</div>
    WOW!
    HOLY COW!
    This is one of those situations where you can feel good, without doing anything! ;~)
    At least, you had the right idea!
    I like neighbors with your attitude.
  9. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(jbarnhart @ Apr 19 2006, 01:58 AM) [snapback]241987[/snapback]</div>
    If you pull your stickers off, the sticky part remains and it is embossed with "Void" all over it. He removed the stickers but didn't get around to cleaning up the mess yet.
  10. RichBoy
    RichBoy New Member
    189
    actually, you havent seen EVERYTHING yet...wait til you see the new 07 Lexus 600h with HOV stickers !
