Backing up on EV mode only
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ricomtl, Sep 2, 2015.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I'm in my 3rd week of driving my new Prius v and was a curious about this...
    During the first week, I noticed that when backing up from my parking lot, the car's engine wouldn't kick in until I'd drive out the driveway at a higher speed.
    Then a few days later, I noticed that as soon as I shift in reverse, the engine kicks in immediately (and the battery appears to be full).
    Is there a reason why?
    Thanks!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Turning on the Engine at startup always has to do with emissions, and in fact the Prius never uses the engine as motive power in reverse. There is no reverse gear, so the engine always turns forward. To emulate reverse, the electric motors run backwards and provide all the motive power.
    ricomtl likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Prius starts the engine after 10 or 15 seconds. If you are quick and reverse as soon as possible, the engine wouldn't start until after you drive away in D.
  4. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Really? I'm going to try this today! Thanks usbeawolf2000 :)
  5. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    The engine will run more often in cold weather to keep the emissions equipment warm. This is to make sure it is functioning properly. When the engine fires up in reverse at those times the driven by the outside temperature.
  6. Mendel Leisk
    41,923
    Yes, this is the one EV mode that's always there. That's comparing to the EV Button, which has about the same odds as a scratch-and-win ticket.
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    This is incorrect. The Gen-3 v models will ALWAYS start the ICE in reverse unless the ICE is warm.
  8. Mendel Leisk
    41,923
    15 second EV mode. :)
  9. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Depending on the state of charge of the HV battery, I've had success backing up without the ICE if I put the car in EV mode right after I push the START button (well, a few seconds after). If the HV battery state is down 3 bars, it will not work. But just backing up right away doesn't stop the ICE from starting up.
