High pitched electronic noise on power up, flickering screens
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wheelsup, Sep 8, 2015.
  1. wheelsup
    wheelsup Junior Member
    82
    Wife pressed power button, "high pitched noise started (constant)", all electronic screens flickered for several seconds, turning from black to green. Dash screen came up first, then radio and AC screens flickered on slowly. Shut car off, had to hit power button twice to shut it off.
    Turned car back on, hit power button, again got constant high pitched noise. Dash and radio screen came up faster (still flickering) but AC screen was slow. Eventually came up. Had to hit the power button 4-5 times to actually get the car to turn off.
    After she took my car to work, I get in and of course experience zero issues (yet). Car turns on, drives fine. Not pulling any codes off the ECU.
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Check the 12 volt battery, also check to make sure all connections including ground are tight. Measure the voltage with a digital volt meter after the Prius has set over night. If it is less than 12.4 volts at the jump post, chances are your battery is weak or toast.
  3. wheelsup
    82
    The 12v battery is what I originally thought of, BUT the car started without hesitation when I went down there to try it. Generally a weak battery will have trouble cranking the car over, and especially wouldn't work better after attempting to start!
    It is original, so around 5 years old, but the car is driven daily so in my experience they've lasted 6-7 years no issues.
  4. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Please understand that the 12V does not crank the engine - it only boots the computers, The traction battery cranks the engine,
  5. wheelsup
    82
    Cripes. I had "forgotten" that (we'll go with that...). So the 12v issue does make sense. I suppose. I guess these cars are different than regular cars with their electronic issues.
    Reading through your battery links people seem kinda picky with the 12v choices in this car. Mine, I threw a Bosch battery bought on sale at Pep Boys and it's worked fine. Is the Prius that picky about which 12v battery you use in it?
  6. DG Bear
    DG Bear Junior Member
    85
    24
    plano, tx
    The car will work with many 12v batteries but there are other considerations.
    Did you buy an AGM or a conventional battery?
    The Prius uses a AGM battery with smaller battery posts and a tube to vent the battery to the outside.
    You'll see lots of interesting comments here and other places on the web concerning the 12v Prius battery.
  7. wheelsup
    82
    I should've specified better. I haven't replaced the battery in my wife's 2010 Prius, AFAIK it's original. By "mine", I meant my car, which is an older regular car, not a hybrid.
  8. wheelsup
    82
    Good lord these 12v batteries are expensive! Around $160 is the cheapest I can find online. Wow. I paid $91 for my other car a few months ago and about died, previous one was a WalMart special for $60 that lasted 7 years!
  9. dorunron
    3,318
    1,103
    Houston, TX
    Yes, the Prius is PICKY about it's 12 volt battery, and YES it is EXPENSIVE.
    Such is life when you drive a Prius. You get the reward of great MPG, but sometimes the repair and or maintenance can be costly. Best to DIY.
    Again, measure the voltage with a digital volt meter as I stated earlier in this thread.
    Remember the 12 volt is only used to boot up the electronics. The engine is started with the traction battery.
    Good luck,
    Ron (dorunron)
  10. wheelsup
    82
    Volts are under 10 if lights are turned on for about 15 secs. I'd say it's toast. Shopping now...
  11. dorunron
    3,318
    1,103
    Houston, TX
    IMO, the best battery for the bucks is the OEM battery. Get one from Toyota and install it yourself. Expect to pay close to $200.00 for it. Make sure it is fully charged. Around 13 volts when standing by itself, measured with a digital volt meter.
    And yes, 10 volts is toast IMO.
    Best of luck to you.
  12. wheelsup
    82
    I called around
    Optima 46B24R for $190+tax
    Advance Auto Generic 46B24R $150+tax
    Toyota Dealer $206+tax
    Got the Advance Auto special. Couldn't resist he price. Fit perfect and had the vent tube hole and everything. I've had good luck with the cheaper batteries, we'll see how long this one lasts!
    I like Prius owners, we are so DIY friendly. Lots of smart people on here willing to help! Thanks Ron!
    #12 wheelsup, Sep 8, 2015
  13. bisco
    48,989
    i'd grab a toyota.
  14. wheelsup
    82
    I just threw out a 10% coupon off parts from my local dealer. Last week!! Had I had that, I probably would've gone Toyota.
    The ~$50 price difference was too much to pass over.
    Here is a pic she sent me this morning of her 25 mile commute to work. She even used AC some of the time! Mostly highway. Car has 94k on it. This is up about 10 MPG from where it was prior. They need to put dash indicator light for that battery, or remind people to check it monthly or something. There are zero symptoms until it gets close to dying. I'm just lucky I was in town to take care of this.
    #14 wheelsup, Sep 9, 2015
  15. bisco
    48,989
    call them, they might honor it.
  16. wheelsup
    82
    Well too late, battery is bought and in the car now :).
