Short distances & live MPG
Discussion in 'Prius v Fuel Economy' started by ricomtl, Sep 9, 2015.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I've been driving a 2015 Prius v for the past 3 weeks and I noticed that the live MPG indicator (MPG after departure) is always poor on short distances. If I drive to the grocery store (about 10 blocks away), flat roads and a few traffic lights, I get something around 20-28mpg on ECO. If I drive just a little longer, I manage to get it down to 35-40mpg. Is this normal?
  2. Mendel Leisk
    41,923
    Yeah I think so. Largely due to engine warm up.
  3. bisco
    52,398
    the pip would be perfect for you.
  4. fuzzy1
    10,603
    Absolutely. Cold starts with short trips hurt mpg on internal combustion engine vehicles in general, and Prius is no exception.
    The way around this is to use an all-electric vehicle, or a plug-in hybrid that can make the trip in purely electric mode.
  5. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Darn! I wasn't authorized to install a plug-in charging station at my condo, therefore I had to opt in for a plain hybrid. Since this car displays live MPG after each start, it's a little more obvious than in my previous cars (I never did a reset at each trip).
    Most of my daily trips are very short - house to train station, house to grocery store... and then on weekends, it'll be a mix of highways and running errands a little further in the city.
    Thanks for the input guys! I learn something everytime I come here!
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    You just have to treat yourself to more road trips! Here is my simplified graph of my mileage.
    ricomtl likes this.
  7. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    hehehe... since I got this car, I keep sneaking out the house just to drive around. I like it a lot.
    Then, is there any benefit of warming up the car (5 minutes) before leaving or should I just start the car and drive?
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Just drive, your gas mileage while sitting still is horrible!
    Mendel Leisk and ricomtl like this.
  9. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Agreed a plug-in is best for these trips. I do three to four of these everyday and burn zero gas.
    It's too late now but the OP can use any 120v receptacle near their parking spot as a "plug station"; no additional equipment or wiring needed. Simply pay the condo association a $20 monthly fee for the electricity.
  10. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    As soon as I move out and get my own house, I'll upgrade to a plug-in for sure!
    There are no 120v outlets near the parking lot and it would require too much work and investment on my end. Also, we don't have reserved parking spots, anyone can park anywhere. 70% voted against such modifications, so they told me to forget it!
  11. Mendel Leisk
    41,923
    You could get the block heater. Two hours plug-in is more-or-less optimum, will raise the car's coolant temp about 20C above ambient. We have it, use pretty much religiously, before the first start-up of the day. It has a side benefit, of making you think twice before hopping in the car for impulse spins. We'll just hoof it, if we need to run an errand really close to home, leave the car parked.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If they can't get a Prius PHV due to no receptacles, where would they plug in a block heater?
    CR94, ricomtl and Mendel Leisk like this.
  13. Mendel Leisk
    41,923
    Whatever :ROFLMAO:
    ricomtl likes this.
  14. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    hehehe!!! :) perhaps I could get a solar powered block heater! Funny thing, I haven't even checked under the hood since I purchased the car so I don't know if I have a block heater plug. Does Toyota equip all northern cars with a block heater? My old Ford came standard with one.
  15. Mendel Leisk
    41,923
    You know, it might. This is REALLY something they should put in at the factory, all vehicles, much simpler then. The sad reality is that 90% of them would never be used though. Our daughter's Ontario Vibe had the blockheater, when they brought it out here (west coast). Totally grungy and never used. :(
    When the dealership did ours, they did not run it out through the front grill, just bundled the cord and plug in the engine bay, on the fuse box side. Look for a silvery, sharp cornered cross-section wire (triangular or square?) snaking down the driver's side, back of the engine. The cord switches from silver wire to regular black cord nearer the plug, it's 3 prong.
    If you look on Toyota Canada it shows the installed price of this accessory around $235 I believe. When we got it put in we got dinged $400, by Open Road Toyota, Port Moody.
    #15 Mendel Leisk, Sep 10, 2015
  16. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Yeah, a plug in is wonderful for getting back that short-trip mileage. It would be fantastic to have them all plug ins, best of all worlds.
  17. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Thanks Mendel Leisk! I'm going to check under the hood this morning out of curiousity. I read a few threads on here of people of bought it from the Prius Chat Store for 59$ and self installed in 20 minutes. 400$ does sound a little steep!
  18. Mendel Leisk
    41,923
    Yeah, the install is not that easy. Doable, but access is difficult. From above, you'd want to remove wipers, motor and cowl. Google "Nutzaboutbolts Prius spark plug" for a good video on this. It's also reachable from below; I believe either approach involves some Braille work, lol.
    $400 seems like nothing when you're cutting a check for around $30K. But yeah, I paid full retail for that one, and it's good that Toyota Canada has cracked down and set an installed price on their website. I'd strongly consider the installed route, at $235. Particular with our exchange rate, shipping and duty charges, any US parts cost balloons by the time it's in your hands. And the grief of DIY on this one is significant.
  19. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The block heater will have virtually no impact on average MPG, its mainly a comfort option for those who want heat right away. Even under ideal block-heating conditions, you'll spend more on electricity than you save on gas. And at $300-400 for install, well that's more than 100 gal of fuel. So if its not worth the money to have instant heat, don't waste your time.
    ricomtl likes this.
  20. fuzzy1
    10,603
    That depends on what else may be on the same circuit. Plug-in cars represent large loads, and must not be on the same circuit breaker as other large or medium loads. E.g. a plug-in car must not share a circuit with another plug-in car, nor even with a bunch of garage lights.
    Without knowing the electrical layout of the facility, plug-in owners should not assume that the simple presence of a 120V receptacle means that it is electrically OK to charge there. Always ask for permission.
    ricomtl likes this.
