Rear Passenger wheel noise....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Xterra72, Sep 11, 2015.
  1. Xterra72
    Xterra72 Senior Member
    1,436
    1,681
    Is it my wheel bearing, rotors or brake pads?
    How do I describe it... well it has this squealing noise and it's proportional to my speed.
    Heard this while I had my windows rolled down.
    Does is have anything to do with my caliper covers?
    This just started today after I went into a dip at about 45 mph. ...
    Anyone know what it might be??
    @sfv41901, @Accordlayingkit ,@Ramtart ,@Burna J @TopRamen, @Johnsk93 @orenji, @apt5020 ??
    Anyone??
    #1 Xterra72, Sep 11, 2015
  2. Ramtart
    Ramtart Senior Member
    432
    797
    San Jose, CA
    Hey bud, if you think it's your caliper cover inspect the cover and see if it's scratched. You can also remove the wheel and see if the caliper cover is loose. Try that first. Good luck!
    Burna J and Xterra72 like this.
  3. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    Like @Ramtart said, just give it a look. Should be easy to see if the covers are rubbing on the rotor or not. If they are, just relocate them and torque them back to spec. I've hit some big dips and never had a problem with them..
  4. Xterra72
    1,436
    1,681
    Did some short distance test drive and I don't hear it anymore.
    Don't know what's going on. Caliper covers are tight. All locking nuts still in place.
    Once I go on my longer commute drive will test again.
    Went on you tube for wheel bearing noise and it does not sound anything like it. Thank goodness. They are expensive to replace
  5. Mendel Leisk
    41,785
    By "caliper covers", what are you guys referring to? This?:
    Sometimes a pebble can lodge between that plate and the disc.
    Xterra72 likes this.
  6. Burna J
    1,071
    3,340
    53
    Long Beach, CA.
    No, that the dust cover for the rotors.... Here's the covers he referring to.
    Xterra72 and Mendel Leisk like this.
  7. Xterra72
    1,436
    1,681
    I'm hoping it was just a temporary pebble obstruction that finally dislodged itself after a few short drive tests.
  8. capolihu
    capolihu Member
    101
    76
    Mont
    Dust cover how it is called, but yes, next to the caliper.
    My question is, as there are really few Priuses if there is any around here in junkyards, those dust covers are interchangeable with another Toyota? brand?
  9. bisco
    52,227
    check fleabay
  10. capolihu
    capolihu Member
    101
    76
    Mont
    right, if ppl in priuschat do not know maybe they will :)
    Burna J and bisco like this.
