New owner of Prius v
Discussion in 'Prius v Main Forum' started by holycow2k15, Sep 12, 2015.
  1. holycow2k15
    holycow2k15 New Member
    salt lake city
    Hello to fellow members! Happy to be part of this forum
    Bought a red prius v (2012 used at 13K miles for $18400) and loving it so far
    Did the 2nd fillup yesterday and mpg is almost 55.
    Loving it - about 3 times my previous car and not to mention the stuff I could haul from home depot which I had to ask someone previously
    #1 holycow2k15, Sep 12, 2015
    52,805
    congrats, all the best!(y)
  3. Mendel Leisk
    42,301
    54~55 mpg in a Prius v? You're doing something right!
    Save your gas receipts and calculate, you'll likely find Toyota is exaggerating a bit. But I understand with the v and c not so much.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Beyond Toyota's suggested maintenance, I recommend changing the transaxle fluid (with ATF WS) near 30,000 miles, near 90,000 miles and then every about 90,000 miles. (Past experience hints it degrades fastest during early service)
  5. holycow2k15
    salt lake city
    Yes I was surprised too since the claims are 40-44 mpg. I drive in eco mode.
    I zero my trip every time I fill and hence can calculate based on that.
    May be my commute has a part in it. I start the day with 25% battery.
    I start off the day on a relatively flat road followed by ups and downs to my kids school. The battery goes up to 75% on the way and ends up at 25% by the time I reach the school. Then I have a full grade down to work by which the battery is almost fully charged. When I return, there is lot of traffic,stops and battery is 50% I reach school. After that I am again mostly below the center line on the engine power and reach home with a 25% battery.
  6. holycow2k15
    salt lake city
    will do. thanks for the tip
