2004 Tax Incentives
Discussion in 'Gen 2 Prius Main Forum' started by wetntacky, Jun 23, 2004.
  1. wetntacky
    wetntacky New Member
    29
    Chicago, IL
    I purchased a 2K3 Classic last month as a Certified Used Vehicle from a Toyota dealer. Am I elgible to receive this tax break or does this only apply to New vehicles?
  2. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    New vehicles only, sorry!
  3. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Check with a Tax lawyer or CPA. You might be able to take the deduction if the previous owner did not.
  4. FarNorth
    FarNorth Junior Member
    35
    Eagle River, Alaska
    IRS Code says "original owner only" also. So you will have to be satisfied with owning a great car and forget about any tax deductions.
    Raymond
  5. Lectricar
    Lectricar New Member
    98
    Glenmoore, Pennsylvania
    So that there is no confusion, here is what the Congress of the United States said:
    § 179A. Deduction for clean-fuel vehicles and certain refueling property.
    (a) Allowance of deduction.
    (1) In general. There shall be allowed as a deduction an amount equal to the cost of--
    (A) any qualified clean-fuel vehicle property, and
    (B) any qualified clean-fuel vehicle refueling property.
    The deduction under the preceding sentence with respect to any property shall be allowed for the taxable year in which such property is placed in service.
    (2) Incremental cost for certain vehicles. If a vehicle may be propelled by both a clean-burning fuel and any other fuel, only the incremental cost of permitting the use of the clean-burning fuel shall be taken into account.
    (B) Limitations.
    (1) Qualified clean-fuel vehicle property.
    (A) In general. The cost which may be taken into account under subsection (a)(1)(A) with respect to any motor vehicle shall not exceed--
    (i) in the case of a motor vehicle not described in clause (ii) or (iii), $ 2,000,
    (ii) in the case of any truck or van with a gross vehicle weight rating greater than 10,000 pounds but not greater than 26,000 pounds, $ 5,000, or
    (iii) $ 50,000 in the case of--
    (I) a truck or van with a gross vehicle weight rating greater than 26,000 pounds, or
    (II) any bus which has a seating capacity of at least 20 adults (not including the driver).
    (B) Phaseout. In the case of any qualified clean-fuel vehicle property placed in service after December 31, 2003, the limit otherwise applicable under subparagraph (A) shall be reduced by--
    (i) 25 percent in the case of property placed in service in calendar year 2004,
    (ii) 50 percent in the case of property placed in service in calendar year 2005, and
    (iii) 75 percent in the case of property placed in service in calendar year 2006.
    (2) Qualified clean-fuel vehicle refueling property.
    (A) In general. The aggregate cost which may be taken into account under subsection (a)(1)(B) with respect to qualified clean-fuel vehicle refueling property placed in service during the taxable year at a location shall not exceed (if any) of--
    (i) $ 100,000, over
    (ii) the aggregate amount taken into account under subsection (a)(1)(B) by the taxpayer (or any related person or predecessor) with respect to property placed in service at such location for all preceding taxable years.
    (B) Related person. For purposes of this paragraph, a person shall be treated as related to another person if such person bears a relationship to such other person described in section 267(B) or 707(B)(1).
    © Election. If the limitation under subparagraph (A) applies for any taxable year, the taxpayer shall, on the return of tax for such taxable year, specify the items of property (and the portion of costs of such property) which are to be taken into account under subsection (a)(1)(B).
    © Qualified clean-fuel vehicle property defined. For purposes of this section--
    (1) In general. The term "qualified clean-fuel vehicle property" means property which is acquired for use by the taxpayer and not for resale, the original use of which commences with the taxpayer, with respect to which the environmental standards of paragraph (2) are met, and which is described in either of the following subparagraphs:
    (A) Retrofit parts and components. Any property installed on a motor vehicle which is propelled by a fuel which is not a clean-burning fuel for purposes of permitting such vehicle to be propelled by a clean-burning fuel--
    (i) if the property is an engine (or modification thereof) which may use a clean-burning fuel, or
    (ii) to the extent the property is used in the storage or delivery to the engine of such fuel, or the exhaust of gases from combustion of such fuel.
    (B) Original equipment manufacturer's vehicles. A motor vehicle produced by an original equipment manufacturer and designed so that the vehicle may be propelled by a clean-burning fuel, but only to the extent of the portion of the basis of such vehicle which is attributable to an engine which may use such fuel, to the storage or delivery to the engine of such fuel, or to the exhaust of gases from combustion of such fuel.
    (2) Environmental standards. Property shall not be treated as qualified clean-fuel vehicle property unless--
    (A) the motor vehicle of which it is a part meets any applicable Federal or State emissions standards with respect to each fuel by which such vehicle is designed to be propelled, or
    (B) in the case of property described in paragraph (1)(A), such property meets applicable Federal and State emissions-related certification, testing, and warranty requirements.
    (3) Exception for qualified electric vehicles. The term "qualified clean-fuel vehicle property" does not include any qualified electric vehicle (as defined in section 30©).
    (d) Qualified clean-fuel vehicle refueling property defined. For purposes of this section, the term "qualified clean-fuel vehicle refueling property" means any property (not including a building and its structural components) if--
    (1) such property is of a character subject to the allowance for depreciation,
    (2) the original use of such property begins with the taxpayer, and
    (3) such property is--
    (A) for the storage or dispensing of a clean-burning fuel into the fuel tank of a motor vehicle propelled by such fuel, but only if the storage or dispensing of the fuel is at the point where such fuel is delivered into the fuel tank of the motor vehicle, or
    (B) for the recharging of motor vehicles propelled by electricity, but only if the property is located at the point where the motor vehicles are recharged.
    (e) Other definitions and special rules. For purposes of this section--
    (1) Clean-burning fuel. The term "clean-burning fuel" means--
    (A) natural gas,
    (B) liquefied natural gas,
    © liquefied petroleum gas,
    (D) hydrogen,
    (E) electricity, and
    (F) any other fuel at least 85 percent of which is 1 or more of the following: methanol, ethanol, any other alcohol, or ether.
    (2) Motor vehicle. The term "motor vehicle" means any vehicle which is manufactured primarily for use on public streets, roads, and highways (not including a vehicle operated exclusively on a rail or rails) and which has at least 4 wheels.
    (3) Cost of retrofit parts includes cost of installation. The cost of any qualified clean-fuel vehicle property referred to in subsection ©(1)(A) shall include the cost of the original installation of such property.
    (4) Recapture. The Secretary shall, by regulations, provide for recapturing the benefit of any deduction allowable under subsection (a) with respect to any property which ceases to be property eligible for such deduction.
    (5) Property used outside United States, etc., not qualified. No deduction shall be allowed under subsection (a) with respect to any property referred to in section 50(B) or with respect to the portion of the cost of any property taken into account under section 179.
    (6) Basis reduction.
    (A) In general. For purposes of this title, the basis of any property shall be reduced by the portion of the cost of such property taken into account under subsection (a).
    (B) Ordinary income recapture. For purposes of section 1245, the amount of the deduction allowable under subsection (a) with respect to any property which is of a character subject to the allowance for depreciation shall be treated as a deduction allowed for depreciation under section 167.
    (f) Termination. This section shall not apply to any property placed in service after December 31, 2006.
    26 USCS § 179A
    Any questions?
  6. Lectricar
    98
    This is what the IRS says:
    Tax Tip 2004-59, March 25, 2004
    If you are the original owner of a qualifying hybrid vehicle — one that combines an electric motor with a gasoline-powered engine — you may be eligible to claim a one-time tax deduction on your federal income tax return.
    Certain Toyota and Honda models qualify for the deduction:
    Toyota Prius — Model Years 2001 through 2004
    Honda Insight — Model Years 2000 through 2004
    Honda Civic Hybrid — Model Years 2003 and 2004
    The deduction amount is $2,000 for cars first put into use before 2004. Under current law, the clean-burning fuel deduction will be reduced by $500 each year, starting in 2004, until it expires. No deduction will be allowed for vehicles placed in service after December 31, 2006.
  7. wetntacky
    29
    Chicago, IL
    My car was was previoulsy owned by the Hertz Corporation and used as a rental so I imagine they purchased a fleet of these cars and received a huge tax benefit. How would one go about finding out if the incentive was granted on a particualt VIN#?
    If the previous owner did not use it, it makes sense to allow the 2nd owner to benfit from it but my thinking is not always what corporate america is thinking.
  8. FarNorth
    35
    Eagle River, Alaska
    Forget corporate America, the IRS only allows the deduction to the original new car owner.
    Like other rulings, if the original car owner did not use the deduction because another business deduction or credit offered a bigger advantage, this does not allow the 2nd owner to use the deduction.
    Enjoy the car, forget the deduction!
